Question about Breville ikon Hemisphere Blender - Silver
I have the Breville ikon Hemisphere Blender When I plug it in nothing happens Where can I get it serviced. Seems like the buttons are not registering for anything to move.
  • Anonymous May 23, 2009
    Light flashes but will not start when we push a button.
4 Suggested Answers
SOURCE: received the Breville Ikon 600
The fuse button of the blender may have been triggered, try look at the bottom of the blender to see if there there is a hidden button like "reset" and press it, then connect the blender to the electric outlet again...
Posted on Jun 11, 2008
SOURCE: blender will not run. the power button is lite but
There is a 10 Amp thermal fuse (SF129E) that is supposed to create an open circuit when the motor windings exceed 133 C degrees. Although this fuse should close again when the motor cools down it can become perminantly damaged. Locate the fuse by following the black leads from the coltrol board to the motor brushes. It's inside a cloth insulating sheath secured against the windings with a metal strap and two ty-raps. I bypassed the fuse with a wire instead of replacing it. It would probably just blow again sooner or later. p.s. you need a T10 Torx screw driver to disassemble (screws under rubber feet) $3 at ACE hardware.
Posted on Jul 22, 2010
gopakumarg43
  • 74377 Answers
SOURCE: Breville Blender BBL600/A. Only pulse touch button
Hello
Its speed regulator electronic circuit inside is faulty. There is a control circut ot determine the time and speed of the blender. It will contain a pre-programmed IC. This board is nor a repairable one. It should be repaced as card basis. Its one touch pulse only energezes. No other speed retulation section does not works, and the IC related to this is faulty. Normaly pre-programmed; otherwise known as {PIC} ICs are programmed by the manufacturing company, and will be difficult to get from outside electronci sparepart market. So you have to contact the Breville service center to get this device repaired. OK.
Posted on Jul 14, 2011
I have a Breville 800BLXL/B blender that won't power on. When plugged in, the power button will not illuminate.
Most likely its the large yellow capacitor on the main circuit board. I've had this fail on my Breville coffee machine and blender.The coffee machine was a 1.5uf capicitor nd the blender 1.0uf.rated at 275vac. what happens is over the years of power spikes and surges etc the capacitor breaks down to a lesser value than its original "capacity. ie 1uf down to 0.3uf it provides enough power to drive the display electronics But not enough to power the relay to turn the motor on.
. there are 3 screws under the label. Peel off the label . remove the 3 screw. remove the fan cover.
to remove the fan . hold on to the blender jar mounting drive and unscrew the fan. a small square nut is what holds the fan on. remove the rubber feet an the 4 star screws under the rubber feet.
you can then remove the base.
Most likely the fuse is OK. However I've found ( in repairing mine) the big yellow capacitor 1uf 275vac is at fault. over time and power surges it breaks down and cannot pass enough "power:" for the power supply to call the relay to turn on the motor. You van get a new capacitor from Jaycar ( aus or NZ ) for about $6.00 . unsolder the capacitor and solder a new one in. reassembly is reverse. Just be careful not to trap the micro swicth wires ( black) under the motor surround.
Jan 21, 2017 | Breville Blenders
I think I overloaded the blender. Seems like it over heated. now the light on controls goes on but blender does not run when I push buttons. I checked the fuse and its good. What else should I check?
If fuse is good and light is on, then you are getting power. Most likely and very very commonly the motor is fried. I have done it myself with 3 of these things.
Dec 31, 2010 | Breville BBL600XL. 5-Speed Blender
This is the second CBL25 breville blender I have had and it has, as with the first, stopped working out of the blue having not had it for very long. A year perhaps. There is a reset button on the base but...
Bridge the reset button with a jumper and see if that fixes the problem. All it is after all, is a breaker.
If that works, just install a line fuse of about 10 amps.
Mar 07, 2010 | Breville CBL25 Moda Bar Work Top Blender
Breville Blender
I need the blend jar for Breville Blender electronic Model BL3. I did not notice that a stainless steel spoon was in the blender. When I switched it on the crossed blade broke off.
Oct 15, 2009 | Breville ikon Hemisphere Blender - Silver
Blender will not run. the power button is lite but
Jul 01, 2009 | Breville BBL600XL. 5-Speed Blender
Any idea where we can get a new jug for a breville blender?
This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
http://www.brevilleusa.com/home.do
Jan 11, 2009 | Blenders
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
Breville ikon Hemisphere Blender - Silver Logo
159 people viewed this question
Top Breville Blenders Experts
Mike
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
