DVD audio and video correctly connected to Vizio TV but cannot find right combo to make it play dvd. Worked once but forgot settings.
  • 10,594 Answers
Power up dvd player, put dvd disc in and press Play button. Now check at back of TV on what AV input you hooked dvd wires, note that AV input number and press input select on remote of TV to bring that input active. You will se dvd player's picture.
Hit "add a comment" button for further query/ info. Please intimate model number of TV and dvd player in reply.
Thanks.
Posted on Apr 16, 2009
Need help connecting a funai dv220fx4 to a vizio m470vse?
Sounds to me like you got the component leads correct but not the composite (video).
See in the link for downloading the manual :-)
Funai 50 years of Excellence in Consumer Electronics
Apr 23, 2014 | Vizio L37 Television
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play...
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Mar 23, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
I would like to connect a DVD player to my Quasar TV/VCR combo. No clue.....
Look in the back or the front of ur tv have a (Video Audio holes In).Look in ur DVD player in the back or the front have a (video Audio holes Out).Used a component AV video cable hook both devices together.Find the Video Mode in ur tv 1 or 2,now play the DVD player with a dvd disc.Now u should be playing the content of the dvd disc.If u don't have a AV video cable,tries websites like Amazon.com,Ebay.com to buy a set of AV video cable.
Dec 10, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
When I try to play a DVD or VHS on my GO Video DVD/VCR Combo machine, I get audio but no video & the TV (Sanyo 37" HD) says "No Input". I've checked connections, the TV has multiple video inputs but I...
  1. I found the problem - on the back of the VCR/DVD unit there are 3 outputs: L (Wht) & R (Red) Audio + Yellow Video out. The cable from it to the TV was labeled Red/Audio,White/Video, and was connected to the R & W outs, but actually the Wht should have been connected to the Yellow Video out. There is so little space in the TV cabinet/stand that even though I turned the unit around to see the connections, I couldn't see the other (Yellow - Video) out until I pulled the cables out. It's working fine now - I'm not sure how things got connected wrong, since it was working OK before - possibly when I signed up for AT&T U-Verse & the installers moved things around. I'm very happy with that service, by the way - better than Comcast & cheaper, and didn't mean to imply the connection problem was their fault. I may have moved things around in the new cabinet & not realized I hooked up to the wrong outs...
Jan 03, 2010 | GoVideo Go Video DVD/VCR Combo
Component video signal between KLH DVD8350 & Vizio 32" PlasmaHDTV
If the Visio TV has more than one input, don't forget to use its remote to make sure the correct input is selected. It probably wouldn't hurt to put a DVD into the player, confirm its running from the front panel counters) and let it keep running as you troubleshoot. At least then you'll know there is an active video source once you find it. Another thing you can try is to put in a music CD, if the player accepts these too (most do). Then when you get the TV set to the right input, at least you'll hear music, and can then go back to trying a DVD.
I know you're using component video, so remember that unlike HDMI devices, the TV is unable to switch to the correct source automatically. So it may just be that you've never had to switch the TV's input source before. Good luck! :-)
Jun 02, 2017 | KLH DVD8350 DVD Player
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
The dvd works fine but the vcr does not. the picture rolls.
The VCR is connected throug an audio/video cable (red, white and yellow) This happen because the electronic ciruitry on the combo "read" that the signal is going out to copy, and this devices have a copyraigh protection circuitry tat don't allow to do this, is not your fault, but making the connections like this, the systems automaticly activate this feature. If you can change the tv with one taht at least have the white and yellow RCA terminals, your problem will be solved definitevily.
Nov 17, 2008 | Philips Magnavox DVD/VCR Dual Player
The insigina combo
i would check the tv TO DVD/VHS COMBO connections OR REPLACE OLD AUDIO VIDEO CABLES especially if the tv plays clearly.
Dec 11, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
