Question about Motorola Mobility RAZR V3
Razor phone won't charge
I have an older razor phone and when I plug it in to charge the key pad lights up but the phone won't charge. It is now completely dead so it won't turn on at all. At first I thought the charger was bad but I tried to charge it on both my wall charger and car charger and nothing happens. What can I do to get it to come on again?
  • 29 Answers
Hi, I had the same problem with my Old Razor, I bought a new battery and that fixed the problem.
New Batteries for Razors are around £6 - £7 online. google it.
Posted on Apr 16, 2009
Bella won't charge
check it with a multimeter and make sure that its putting out the correct amount of volts, it should be at least 24 volts
May 21, 2012 | Razor USA Razor Pocket Mod Electric...
Razor will not take a charge, will only function when plugged in.
Sounds like the batteries are shot. They can be replaced if you're handy with a soldering iron.
Apr 30, 2010 | Norelco Rechargeable Cordless Men's Razor...
My razor will not turn on and will not charge. when I try to turn it on the lights on the key pad flicker and the screen is blank
Please chech your phone charger with any other compactible phone for its faults.may be the charger is not working properly & its is not able to charge your phone
Feb 25, 2010 | Motorola Mobility RAZR V3
RAZOR v3 -- i have 2 batteries, both good, 2
try taking out the sim and blow the stuff out of it. Then put it back together and see what happens
Dec 29, 2009 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
My razor wont turn on. The key pad lights up but thats all. Also, my computer says that it has found new hardware but none of the moto programs see the phone.
You need to get your phone checked. The computer is detecting hardware because its just the USB connection it has detected.
regards
Sandeep
Oct 13, 2009 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
7526 twist cord and razor speeds up
Based on the limited info provided, it appears you have a rechargeable razor that you plug in to recharge.
I had this occur with an older shaver I had years ago. The suspected issue is tha the battery isn't fully charged and the razor is running on battery power while the cord is plugged into it and the power outlet.
However, the cord is making a loose connection at the razor or has a broken conductor in the cord. So and what is happening is that you arfe getting an intermittent power connection that allows the power to run the razor, which would be why it seems to "speed up" as any rechargeable product always run faster/better when connected directly to an electric power source.
You can look at the plug on the razor to see if the pins/connector is loose, and also carefully check the cord to see if shows signs of having been sharply kinked or bent at the razor plug end or at the power plug end or along it somewhere.
It could be as simple as replacing the power cord. Or you may have to take the razor apart to repair the charging socket at the razor to resolve this issue.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Health & Beauty
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Jul 14, 2009 | Norelco Rechargeable Cordless Men's Razor...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
RAZOR V3
it shows that you are having flex cable issues - common problem with the v3. you would have to bring it to a local repair shop or order a keypad flex and button flex cable to do yourself.
the parts are about $15-40 and a shop will charge about $25 to install
if all else fails contact me and we can help arrange it.
Feb 01, 2008 | Motorola Mobility RAZR V3
RAZOR V3
HAS IT BEEN WET? IF SO OPEN BATTERY DOOR AND REMOVE BATTERY THEN POUR RUBING ALCOHOL NOTE MUCH THEN VACUME NOW PLACE IT UNDER POWERFUL FAN OVER NITE.TRUST ME IT WORK'S...
Motorola Mobility RAZR V3 Logo
193 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
