Black screen mag innovision 568 screen is black
  • 36 Answers
Depending on what kind of laptop you have, your button may look different. Look at the Function keys (all those keys up at the top that have F's in front of them) and see if there is another colored symbol on any of them. You should find a colored symbol that looks like a rectangular monitor.
Press another key toward the bottom of your keyboard that probably says "Fn" or some other kind of "Function" key - not Alt, Ctrl, or Shift. Hold that Fn key down while you press the first key you found that looks like a monitor. That will change your laptop video output mode between several different modes like: laptop LCD panel only; LCD panel and external monitor; and external monitor only.
The purpose of this is if you wanted to plug another monitor into the back of your laptop, or a projector for a meeting or presentation, etc.
Posted on Apr 16, 2009
MAG Innovison LT685 an Mac OS 10.9.2
Considering your file is a media file you should go for digital media recovery software. I can suggest you few, must try Stellar Phoenix (http://www.stellarinfo.com/mac-photo-recovery.htm), Disk Drill (http://www.cleverfiles.com) and Wondershare (http://www.wondershare.com/data-recovery/)
Mar 02, 2014 | Mag Innovision LT Computers & Internet
Black screen
It is most likely that the filter capacitors on the power inverter board have failed. I took mine apart and found seven swollen capacitors on the this board, they fail prematurely and seem to be the only thing wrong with the unit. I replaced them and now it is working just fine.
six 470uf 25v electrolytic capacitors and one 220uf 25v Capacitor.
you should not attempt to repair this yourself unless you have some electronics training since there is a shock hazzard involved and also these capacitors will blow apart if they are installed incorrectly (very messy experience).
Jan 31, 2009 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
May 06, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor Message = "No Signal"
see i use Compaq too
they don't generally except other modes
did u try that monitor with other pc where it worked
u should install proper monitor software ... u will found it from the cd given wit Ur monitor
Apr 24, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Does the MAG LT-456s require drivers
Perhaps your screen resolution is set too high. Try using a different display to set your resolution to 800x600, then attach the MAG display. Adjust from there once it is working...
Mar 08, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
SCREEN DISPLAY BOUNCES UP AND DOWN
Check and make sure that the speakers and any power supply (UPS) are not placed very close to the monitor.
Feb 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
MAG monitor is all white
please change your ram immeditately or monitor itself because the life of monitor has been came to an end...
Dec 31, 2007 | Mag Innovision InnoVision LT765 17" Flat...
Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
