Question about Home
Water pressure to main hose has ceased, with water now pouring out of a small outlet pipe at bottom of unit next to fixing for main hose.
  • 88 Answers
Sounds like your outlet at the top has clogged with grit/dirt. Turn the shower off, remover the entire shower head hose from its base (where it screws into the wall or pipe. Turn water back on. If you get a steady flow (as you should) the problem is isolated to the shower head/hose. Detach the shower head from the hose and clean the screen inside, attach hose back on first, try water again, if this flows then your blockage is in the head itself. After removing and cleaning the screen inside the shower head, reattach and run water, this should fix your problem, if not, you may need a new shower head. If the water will not flow to the outlet pipe alone, either your shower switch is broken or you have a serious plumbing problem.
Posted on Apr 16, 2009
Water pours out from washer
Most washer i know of have a small hose coming from the base of the tub abd going up to a water pressure switch up in the controls. As the water level rises the pressure inside the tube rises. When the water level gets just right the pressure inside the switch kills the water and starts the motor. So what goes wrong? Trash and sediment such as sand gets into the tubing. Removing the tube from the control and blowing it out in most cases fixes the probo. Note: If you do this you need to pump out any water in the machine before you start another wash cycle. So that the pressure will build once again in the tubing and shut off the washer at the correct fill.
Sep 04, 2013 | Washing Machines
Thermostat gasket blown
Is it all one piece, the outlet pipe and the t-stat housing? The gasket goes on the bottom of the housing where it mates to the engine. If the coolant is leaking from the bottom of the housing, that would require a new gasket. If coolant is leaking where the radiator hose connects to the pipe, have you tried tightening the hose clamp?
If the outlet pipe and housing are separate, there may be an O-ring seal between them. You may want to pull off the radiator hose and check if the pipe is so badly corroded and rusted that it cannot seal anymore, or may have a hole in it, especially if it is thin metal.
Jan 09, 2013 | Mitsubishi Mirage Cars & Trucks
What is error code F05?
F05 - Pressure switch jammed on full, your pump/filter/outlet hose is blocked. Make sure you clean it all out with the power off. The pump and filter are located under the drum but your outlet hose may be plugged as well. If there is no obstructions in the drain assemblies then your pressure switch may be bad. First disconnect your machine from the mains power supply. Remove panel at rear/bottom of the machine (cross head screwdriver required). This reveals drain pump (back right corner, as you face rear of machine). To release/remove pump, slide assembly to left and lift (requires a little effort). As mentioned, there will be a fair amount of water in the pump/pipes, so ensure a bowl and absorbent cloths are to hand.
Unscrew two Jubilee clips and three further screws (requiring Allen key).
Clear debris, flush pipes and reassemble.
If this info is helpful a vote with the thumbs up would be greatly appreciated, Thanks for using Fix Ya
Jul 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Black and Decker PW1300 Type 1 Pressure Washer The unit will not pressurize, the motor stays on, the water ways seem clear, a low pressure stream (normal for "motor off") comes out when I...
Hi and welcome to FixYa, I am Kelly.
Not sure if anyone has responded to you but.... This is a symptom of the unloader / bypass valve sticking. The unloader bypass valve is located on the output side of the pump either under a brass cap or an extended stem with a knob on it for pressure adjustment.
Try this...
- Lay the unit down so that the water supply connection fitting is facing up. Leave the high pressure hose connected with wand. (Power to the unit)
  • First inspect the inlet screen for debris.
  • Next pour about 3 oz of regular automotive engine oil in the water supply fitting. Take your time... do momentary on / off cycles of the switch (bump the pump.... on / off) You are trying to get oil to the outlet fitting (No more than 1 second on off cycles)
  • Check for evidence of oil at outlet fitting
  • Leave it set overnight with oil in the unit. (Water supply and outlet fittings up.)
NEXT DAY.... add 2 oz more oil and connect water supply. (PURGE HOSE of ALL air before connecting)
  • Do not pull wand trigger yet
  • Cycle unit on and off about 10 times slowly... don't ruin the switch then let sit 10 mins.
  • Turn unit on without triggering and let run for about 2 minutes.
  • NEXT STEP be advised your going to shoot out OIL
  • Begin triggering the wand on 1 sec off 3 seconds for at least 2 minutes (your trying to get the unloader bypass spring / plunger and seals to start moving inside the pump high pressure area.)
  • If your wand has a soap application function make sure the wand is in the HIGH PRESSURE position. (Closed CCW)
This procedure does not always work but, I have revived about 70 % of the pressure washers I worked on by just doing these steps. If the procedure does not work... you will have to disassemble the unloader / bypass valve by pulling it out of the housing and then cleaning up the inside of the pump housing and wiping the seals clean. IMPORTANT STEP here: Before inserting the valve back into the pump housing you MUST lubricate it with #105 white grease. Housing and unloader / bypass valve parts. (white grease in small tubes at any automotive parts source.
Thanks for choosing FixYa,
Kelly
Feb 24, 2011 | Garden
Drum wont turn water wont drain checked pump suspect frost indrain hose inside washer drain pipe seems crunchy
Your probably on the right track,if you can expose the drain pipe to heat to melt frozen portion would be an idea or you could pour hot water back the drain hose(at its outlet) to melt the water in front of it-thats the most obvious thing first anyway,small socks are a nuisance also getting clogged in drain at exit from drum to drain pump
Jan 08, 2010 | Indesit W 123 Front Load Washer
No agitation mode
blow down the small pressure switch pipe(remove it from the pressure switch)it should be clear,you should hear when you open washer door and blow down pipe,bottom of pipe often gets blocked with caked powder,a boil wash every so often eliminates this type of problem hope this helps
May 27, 2009 | Hotpoint Washing Machines
Check water light is on
I had the same problem! First disconnect mains power, then switch off the mains water to the water input hose, and disconnect the hose. Disconnect the waste outlet hose from your drainage. ( this will release some water from the hose ends, so a washing up bowl would be handy ) You will need to tip the dishwasher on to it's back, be carefull not to damage the waste outlet hose, and watch out from more water spillage. Next remove the two screws on the base metal cover, and spring out the cover from the two side clips, the cover can then be removed, you should have a screw holding an earth lead remove screw and lead from cover.
Inside the bottom of the dishwasher you will see a small electric pump fitted to the side of the dishwashers drain, it has two wires with spade connector on them, disconnect these from the pump noting colour of the wires for reassembling. The pump has the same diameter hose as the outlet hose. Next carefully remove the rubber elbow pipe from the pump and hose end this will need to be washed with clean water. Then to remove the pump, press and hold down the locking tab, where the pump is fitted to the drain, and twist the pump anti-clockwise. The pump will then release from the drain. Inspect the pump impellers for damage, and that the pump has free movement, also check condition of the rubber O-ring. Inspect inside of drain for broken bits of china and glass, remove and clean, also check the outlet hose for any blockages.
( run some water though the hose backwards from the water tap and collect it in a bowl from the pump end of the hose ) Reassembly is the reverse of the above, check electrics inside have not got wet, if ok switch on. The check water light should now be off.
Alan
Jan 11, 2009 | Bosch 24 in. SGS43C12 Classixx...
Drainage Problem
If you have access to an air compressor try blowing the blockage out. Apply air pressure from the outlet as to blow the obstruction up the pipe, not down. If at all possible disconnect the pipe from the air conditioner unit as not to blow debris into the unit. Clean up the mess this will make so it does not wind up back in the pipe. If you do not have access to an air compressor the next best thing would be a garden hose. Follow the same procedure as above. Worst case senario replace the pipe. If you need further assistance with this problem feel free to contact me at geokohler@gmail.com I have yahoo phone out so I can even call you free of charge.
The water pressure from the hose should be more then enough to blast the pipe clear. Just make sure you blow the obstruction from the bottom of the pipe upwards! If you try to force it down it will only jam the obstruction deeper making the problem worse. If it is a flexible pipe you can also remove it from the RV and wiggle it around as you apply water/air pressure. If you use air pressure make sure you use eye protection as debris may fly at dangerous speeds!! Also with air follow with water to was the pipe also. Hope this gets you fixed, If not get back to me with any questions you may have.
Sicerely,
George
Sep 10, 2008 | Dometic Rooftop RV Air Conditioner
F-04 flashing on my Hotpoint WT960 washing machine
F04 is an error code for the pressure switch not sensing the water level.
This may be a faulty switch, or more likely cause is a damaged rubber pipe connecting it to the drum area.
To have a look, Turn off and unplug machine, turn off water inlet.
Move the machine out to ge access to the back.
Remove the top rear screws, and slide the top off.
The pressure switch will be connected to one of the small hoses. Check all the hoses for condition and chafing, and that they are still attatched. The pressure sensor woll be a small unit plugged into the end of one, with a hose going straight down past the normal water level - possibly down to the bottom pump area. It usually is connected to a small inverted empty canister.
If the connections and hose seem fine, you can test the switch by blowing hard into the end of the attatched hose (you have to take it off to test with hose attatched)
I can find replacement parts dealers for you if you specify your main town.
Thanks for using Fixya! - if this provides a solution, please take a moment to rate it as such. Thank you.
Jul 01, 2008 | Hotpoint Washing Machines
WF000
hi the filter is located at the back of the machine you have to unscreew the pastic panel at the bottom..look inside at the right hand side black hose with big jublie clip the filter is inside there just undo the big clip ....expect WATER !!!!!!!!!! when done make sure you push the hose on properly !!! didnt do that myself ...and had to mop up again !
DONT FORGET TO UNPLUG THE MAINS LEAD !!!
Apr 27, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Home Logo
421 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
