Question about HP Pavilion a656x PC Desktop
I have an HP Pavilion a656x computer with two SATA connections on the motherboard. BIOS doesn't give option to enable them. How do I??
  • cfr1102 Apr 17, 2009
    thanks for the thought "joecoolvette" but I've already tried that (in both SATA1 and SATA2 motherboard connections, and the system doesn't see it. tried installing fresh copy of XP Pro to that drive after removing IDE drive.. and drive is not recognized. any other suggestions?
  • HP Master
  • 5,660 Answers
BIOS doesn't give any option to enable those Sata headers, it's automatic. You just pick a Sata header, and plug into it.
Any one you want. BIOS will automatically recognize, that there's a device plugged in, and to THAT Sata header. That's what's nice about Sata.
Posted on Apr 16, 2009
  • joecoolvette
    joecoolvette Apr 17, 2009
    When you reinstalled XP Pro, did you see where it asked if you wanted Sata drivers? You have the option to use it, or skip over it.
I bought an hp p6130f, it is a bare bone (CASE AND MOTHERBOARD, ONLY) the problem is that the motherboard does not recognize any hard disk I connect, I tried all 4 SATA connectors, still, it asks to...
The only thing I can think of off the top of my head would be to reset the bios (there may be a jumper to do so....or check your manual) or see if there is an updated version of the BIOS for your motherboard. Anything BIOS related be sure to get EXACTLY the right update for your motherboard and make sure you follow the instructions EXACTLY. Making a mistake when flashing the BIOS can kill your motherboard.
Mar 06, 2013 | HP Pavilion p6130f PC Desktop
Sata
First, try a different sata cable...
If that doesn't work then flash your Bios to the latest version. You can get it here:
http://www.msi.com/product/mb/K8MM-V.html#/?div=BIOS
Aug 29, 2012 | MSI K8MM-V Motherboard
I got a compaq presario sr1130nx, and i tried to install and sata hdd but it does not appear on the bios screen, it's not detected at all...
According to your problem first make sure that the hard drive is OK and working fine. You can attach with another PC to be sure that the drive is OK. If the hard drive is working properly then change the SATA cables (data and power). Check that you have connected all the cables properly with motherboard, SMPS and hard drive. Make sure that the hard drive is motherboard supported. If it doesn't solve your problem then change the bios settings. Make SATA enabled in bios. Check the SATA mode in bios. Proper bios settings can make your drive working if the drive is OK. For proper bios settings you can take help from motherboard manual.
Jun 29, 2011 | HP Sr1130nx (PC134A) PC Desktop
Picked up a HP dc7100 but will not boot from sata
You should have an option on the dc7100 in bios to enable sata in the devices section. Mine always worked fine with sata. If nothing else works remove the security chip, reset the cmos and reboot with the Hard Drive connected and it should connect. If that doesn't work Try flashing the bios just in case it got corrupted.
Mar 12, 2010 | HP (REFURB) HP DC7100 XPP P4 3.2GHZ 80GB...
System not recognizing dvd writer. new build. 2nd one I took the first one back thinking it was defective. HP dvd1270i dvd writer
Could be the motherboard's SATA connection is bad or not activated in the BIOS. I assume you have tested the SATA cable and verified that the SATA power connector is working. You may need to verify in the computer's BIOS that the SATA settings are on and correct. Do you have another SATA drive that is known to work that you can test in the computer to verify the SATA connection is working? Also some motherboards have a jumper on the board to disable and enable the SATA connection on the board. Verify that if there is a jumper it is in the correct position.
Nov 10, 2009 | Cars & Trucks
My laptop went all wrong when i formated it...
Your sata is enabled in bios you need to disable it first.
When you power up the computer pressF2 or "del" key to enter in bios .
Then disable SATA option then save settings then check.
Thanks for using fixya.
Please rate my solution if it helps.
Jul 21, 2009 | HP Pavilion dv9000z Notebook
My cpu dont see new hdd wd5000avvs ,motherboard Asus P5LD2 SE. i trying omost everything. help;/
are you using ide or sata connection? if your using sata conection between your motherboard and harddrive, you must enable it in your bios, just reboot your pc and keep pressing F2 while its booting to prompt your bios. There you can look for IDE/SATA configuration. After enabling your sata, save any changes before you exit and reboot... Just give it a try...
Jun 22, 2009 | ASUS P5LD2-VM Motherboard
Computer doesn't see new secondary hard drive
There is no option in the bios to enable sata. It appears that the sata ports are just for decoration (hence hp using IDE)
May 13, 2009 | HP Pavilion a620n (PC028A) PC Desktop
I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Mar 31, 2009 | ASUS K8S-MX Motherboard
HP Pavilion a656x PC Desktop Logo
202 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
