Question about Frigidaire ATF6000ES Front Load Washer
Loud clunking in final spin
It is making a loud clunking noise, like it is off balance. It is also leaving pieces of white plastic shreds in my clothes.
What could be causing this? Will it be an easy fix or time to buy a new one?
It is a Frigidaire Model#GLTF167OSAO, is is approx. 6 years old.
I had the same problem. Thgought maybe the legs needed adjustment. Took the bottom front cover off and saw that the "Shock absorber on the right side was broken and was not providing any support. The shock on the left appeared ok. These shocks were round and the attachments were made of white plastic. (maybe your source of white plastic debris you have been seeing. Local applicance part store had parts. The shocks come in pairs (different design) I replaced both and everyone in the family is amazed with how quite and smooth the washer runs now.
Posted on Apr 27, 2009
  • 198 Answers
Time for a new machine, fix is very expensive, machine needs basket support, called a spider, parts are about 300. 00
Posted on Apr 18, 2009
When it hits the spin cycle the drum makes a loud clunking noise, and found some white plastic piece that came out.
Sounds like the drum bearings have gone. This is a big job to do. If the machine is 5 years old and has done a lot of work, think about a new machine as may be cheaper in the long run.
Nov 04, 2013 | Kenmore HE3T Washer
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
My Kenmore Elite HE3 Mod 11044832 202 started making LOUD knocking noises during final spin cycle, then started to smell like something burning. Whit placis shreds in the washer.
the plastic is the drum has dropped so its eating a way the plastic on the back of the drum so no not worth fixing the mould is an easy fix just soke a cloth with neat bleach and leave over night make sure you do a rines after woulds as you don't want bleach on your cloths ok
Oct 21, 2012 | Kenmore 44832 Front Load Washer
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Loud noise in final spin - had technician check washer - found pieces of broken conrete (cement) in the drain tray with shreds of gray hard plastic. said everything was fine--4 hrs later- did one cycle...
Hi! The technician should check the drain hose also, cause maybe there are some broken big parts of plastic or cement stuck inside. I hope this will help you! Have a nice day!
Sep 02, 2011 | Washing Machines
My Duet Washer by Whirlpool is about 6 years old and it started making a loud noise during spin leaving shredded plastic in tub. In talking to the repairman, he said if the arms are broken, they would...
i just had my washer do this to me last weekend. In the final spin out it made a loud noise and i noticed that the plastic between the metal tub and the outer plastic tub was rubbing away.I'm going to tear into it my self being that its out of warranty. Mine is about 6 years old too.
Nov 19, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
THE DRUM WHEN SPINNING MAKE LOUD KNOCKING NOISE? THERE ALSO IS LONG MELTED PLASTIC PIECES COMING FROM FRONT DOOR AREA.
the plastic pieces are from the friction of the metal spinning onto the white plastic, Part cost about 187 but I am thinking of just ditching this crappy washing machine, something is always going wrong. call me 3616432681
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer makes noises
You said, when the washer is going into spin cycle it makes a loud clunking noise. You are wondering if this could be the brakes or possibly the pump?
Sounds like this!
Faulty direct drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The direct drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
it can also be a broken spring or strut dependping on your washes make and type
Please remember to leave a rating
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
Loud banging on spin cycle frigidare washing machine model no. fws235rft2
If this is a front loader this is a common problem. Unfortunately, it is also a very extensive project (about 8 hours). The tripod supports that attache the drum to the center spindle commonly break. The remedy is to replace both the front and rear tub, and the basket as well. It is also recommended that you replace the drain pump as well. Generally, they will cover the parts (not including the drain pump) under warranty but the labor will be a customer pay.
Oct 19, 2008 | Frigidaire Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
517 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
