Question about Sharp AR-M455N Copier
Sharp AR M455N copier scanner will not scan to Windows 2000
The scanner will not scan to a Windows 2000 Laptop. We get a network error CE-02
  • 1 more comment
  • rlb486 Apr 20, 2009
    We can print to the copier.
    sharpdesk is loaded.
    Profiles are set up and scanner is listed.
  • hayden du plessis
    hayden du plessis May 11, 2010
    A few questions :
    Can you print to the copier?
    Do you have sharpdesk loaded?
    Have you setup profiles and have the scanner listed in the network scanner application?
  • Anonymous Mar 24, 2014
    I can't scan to my email. This error code keeps coming up. I have used this machine for months with out this issue. it seemed to have just popped up.
    Scholar:
  • Sharp Expert
  • 120 Answers
Right-click on the scanner tool icon in the tray, go to Automatic Profile Update, then Update Now.
If all else fails go to the web page and clean out your old profiles in the address book. Go to the network scanner tool and clean out your old profiles, recreate them and Apply.
Posted on Feb 12, 2010
    Sniper:
  • 54 Answers
Check the webpage under destinations and make sure the IP address is correct for this pc. can get to webpage by opening Network Scanner tool, hitting the scanner tab, then web setup button.
Also make sure the Network scanner service is running in the system tray (by the clock) and that it says the service is started by hovering over it with pointer.
Posted on Apr 17, 2009
What is network error (CE 03)
There is something not setup at all on the webpage or setup wrong on the webpage of the copier to allow you to scan to email. Need an IT guy make sure that your SMTP, DNS and reply address are correct on the webpage of the machine.
Nov 01, 2011 | Sharp AR-M455N Copier
I have a Sharp AR-M550N; It's giving me a code Network error CE -02? How can i solve that error?
CE 02 is rarely a machine problem, It normally is an addressing problem between the machine and the network. That code indicates a communication problem, normally relating to scanning.
Often times it is a wrong character in an address.
Feb 01, 2011 | Sharp AR-M550N Copier
AR-M455N Error Code CE 02 thank you
how change serial number logical in sharp arm455
Feb 01, 2011 | Sharp AR-M450N Copier
What is Network error (CE 02) thank you
Network Error CE-02 - this is where the machine cannot communicate with the SMTP Gateway / Mail Server for scanning. Check that you have a connection with the network and that you have the correct SMTP I.P address.
If you are using a host name for the mail server make sure that you have configured the DNS entries correctly.
Hope this helps.
Feb 01, 2011 | Sharp AR-M455N Copier
Our machine is a Sharp AR-M55OU and it is giving us the error CE-02 when we try to scan. What does that mean?
I believe the CE-02 is a generic network error.I had the same issue, with us it was a DNS issue. We had old computer accounts in DNS confusing the scanner when using hostname. Have your network admin scrub DNS and see if it solves it.
Sep 03, 2010 | Sharp AR-M350U Copier
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Error code CE-02 when in the scan mode.
the FTP server cannot be found. This is a network error. If it is connected to a network, check with your IT person to set up the FTP server.
Apr 13, 2009 | Sharp AR-M455N Copier
Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
Apr 09, 2009 | Sharp AR-168D Black and White Copier
Error CE while scanning though N/W in Sharp AR M-205
If subcode is 00 then network connection is problem, if 02, then its not talking to the network scanner tool on the computer. Might be an IP address problem, where the address in the webpage of copier is wrong for the PC.
Mar 19, 2009 | Sharp AR-M205 Copier
Sharp AR-M455N Copier Logo
650 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
