Question about Canon CanoScan 4400F Flatbed Scanner
I get an error code of 2,107,0 when I try to scan negative film. I do not have a listing of error codes and would like advice on what the message means. (The scanner is a Canon Canoscan 4400F, a bit over a year old. The scanning of documents is still fine.
  • 13433 Answers
SOURCE: canoscan 4400F
Well, lets start with geting the newest software for your product.
select your operateing system and language and download the newest versions from here
http://software.canon-europe.com/products/0010399.asp
Posted on May 17, 2008
  • 111 Answers
SOURCE: Problem with CanoScan Lide 500F
I would reinstall the driver first. Get the latest ScanGear and Toolbox from the Canon Website.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=11011
Do you have any other image devices such as a Multifunction (scanner,fax, printer) or digital camera attached to the computer?
Posted on Jul 09, 2008
  • 461 Answers
SOURCE: CanoScan Scanner can not complete a scan
Double-check all connections and try another port if possible. There may also be damage to cables or pins. Do you have another cable to try? Do other devices work in the same port?
Posted on Jan 10, 2009
SOURCE: Slides scan as negatives
this scanner usb cabal no didact tell me bored problam ya cabl problam 6600E
Posted on Feb 16, 2009
  • 17 Answers
SOURCE: Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
Posted on Jun 11, 2009
Code 2, 189,0
All scanners come with the scanning head locked to prevent damage to it during shipping. On the back of the scanner, where the power cord and wires connect, there will be a sliding switch, sometimes a turning type lock, with two positions, one with the icon of a closed [so locked] padlock and the other with the icon of a open [so unlocked] padlock. Every scanner I have bought describes this lock in the setup manual.
Oct 17, 2014 | Canon CanoScan 9000F Mark II Color Image...
Epson wf 7520 "scanning negatives"
I also Have a Epson WF 7520 and I cannot scan any film I've tried every thin here listed I called Epson Support and they said this all in one can't do negatives but it has a slot for it don't understand how you all can Please need help
Apr 12, 2014 | Epson Office Equipment & Supplies
Canon 8400F will not scan, error code 5, 155, 45
If it passes 'test' from the computer, then it should be listed in the Device Manager. Uninstall / Remove that device, then Restart and Re-install it.
Tallon41
Aug 22, 2012 | Canon CanoScan 8400F Film Scanner
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
Problem scanning film with EPSON V300
check if upper cover remove for film scanning, bulb must be visible upon scanning in negative or positive film.
Feb 04, 2010 | Epson Perfection V300 Film Flatbed Scanner
Epson 4490 scans with colour streaks/ digital interference
did you properly close the scanner lid? these type of errors do usually occur when you unproperly close the lid wherein light passes inside causing it to reflect on the document that you are trying to scan
Sep 13, 2009 | Epson Perfection 4490 Film / Flatbed...
Negative or positive option is not available on drop down menu on select source on ScanGear CS so how do I scan film? I am trying to scan 35mm film on my Canon 5200 F scanner using ScanGear. The manual...
I just had the same problem, turned out my FAU cable was not properly connected. Ensure that the cable is all the way inserted at the back of your printer, and connect the device to your computer. I hope this will work for you too:)
Jun 24, 2009 | Canon 5200F Flatbed Scanner
Loading negative film in holder.
The button under the top door is for ejecting the film strip. To load negatives you just insert them until the machine recognizes them and then it will automatically load them.
Apr 12, 2009 | Epson Perfection 3590 Photo Flatbed...
Film holder problem
try this
Turn on the scaner (diode is blinking), then run aplication DS Dual3
After start application you sould hear the transport mechanism test.
The green diode should light permanently (important).
Push deeper the holder.
Jarek
Jan 29, 2008 | Minolta Dimage Scan Dual III Film Scanner
Canon CanoScan 4400F Flatbed Scanner Logo
414 people viewed this question
old marine
old marine
