Question about Canon ZR70MC Mini DV Digital Camcorder
Battery drain on Canon zr70mc
I have two canon zr70mc camcorders.On my first one,the tape door stopped working,so I found another one cheap that works great except the batteries drain within 10 minutes.Even the higher capacity battery.I did a test and put a fully charged(I think) battery in my broken cam and left on camera mode and after 30 minutes the battery stil had plenty of charge.It seems that the second camcorder has a battery drain problem.I've searched all over web and can't find similar problem.Can you shed some light on this situation for me.Thanks
  • keana30 Jul 03, 2008
    yes I do have the same problem HELP!! same kind of camcorder I am so not camcorder lingo literate! What should the button be on in the LCD screen? We got a killer deal with this new looking camcorder but it will not hold a charge we can only use it when we are tethered to the outlet. Any suggestions
    Thanks-Roxanne
  • motoxracer75 Nov 02, 2008
    My Canon ZR70MC Has a similar problem. The camera will only turn on when its plugged into the wall. I have two batteries and both dont turn the camera on! they are fully charge too!! So i bought a new battery and charged it fully and the camera still wont turn on. It only turns on when plugged into an outlet. Please Help!!
I need a way to recharge my batteries but I can't find my charger? How and where can I find one?
Posted on Jul 12, 2008
    Problem Solver:
  • 14 Answers
If you have the idiot proof switch on, it makes everything AUTOMATIC and drains the batteries fast. Open the LCD door and check if the switch is in the wrong position and change it. Go into the menu and set thing s the way you want them. The more Auto stuff you have on, the faster the battery goes. Are you using a light? Even using the LCD uses more power than the viewfinder. Also, batteries do go bad. It's best to run them all the way down and recharge, if you haven't been doing that, short life. I buy my batts on ebay. Instead of one for $150 I get 10 three hour batteries for that.
Posted on Jan 09, 2008
SOURCE:
How long recording time with a dv tape in canon zr70mc
That obviously depends on the length of the tape. With an 80 minute tape, you can record for 80 minutes in SP mode or 120 minutes in LP mode. With a 60 minute tape, the numbers are 60 minutes and 90 minutes.
Sep 11, 2013 | Canon ZR70MC Mini DV Digital Camcorder
Can i use Adobe Premier to import minidv from canon ZR70MC to Windows7?
run 3
Thank you for your blog post.I admire the valuable information you offer in your articles. Thanks for posting it, again! Really looking forward to read more.
Feb 14, 2013 | Canon ZR70MC Mini DV Digital Camcorder
I HAVE A CANON CAMCORDER ZR70MC THE CARD PLAYS BUT THE TAPE WILL NOT PLAY IF SOUNDS LIKE ITS TRYONG TO PLAY BUT NOTHING PLAYS
Try to clean the VCR head.  You can buy a tape cleaner from Walmart.  It is not cheap!  It is about $15-$25.  Or you can clean it yourself (on your own risk) by using alcohol 91 and a soft cloth.  Clean the head going in one way (one to two times only,)  NOT BACK AND FORTH.  THE HEAD OR HEADS LOCATED ON THE DRUM (THE ROUND SILVER OBJECT)
Sep 08, 2010 | Canon ZR70MC Mini DV Digital Camcorder
Tape transport stuck in open position. Will not take tape into unit.
It could be possible that the tape is in the wrong way or that the tape is the wrong size those are both reasons that it may not be closing
May 25, 2009 | Canon ZR70MC Mini DV Digital Camcorder
Canon ZR 600 tape won't load
The capstan motor is broken and needs replacement. You could send it in for repair but it wouldn't be cheap.
Dec 31, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Battery pack for Canon ZR100 digital videocassette camcorder
For good spare canon nb-2lh battery,or cheap replacement canon nb-2lh digital camera battery,you can search and searh to find a famed relible camera camcorder batteries store with chargers on sale,shopping online convenient and cheap !
Jun 25, 2008 | Canon ZR100 Mini DV Digital Camcorder
Digital video camcorder
Try the most obvious solutions first; making sure the AC adapter for the camera is plugged into the camcorder-- and the plug orientation is correct if applicable, and it is in turn plugged into the wall.
Is the wall outlet working? Try another location in your home to be sure. Is the AC adapter working? If you have a battery, attach it to the camera and see if it charges. Next, look for obvious outward physical damage to the camcorder that could cause it to stop working.
The thin battery you speak of if generally just for backing up the time and date, and is not needed for operation.
The power switch on Canon models is usually a slider that goes from Manual to Auto to VCR mode. If it is dirty or wearing out, move it a small amount to one side or the other, while watching the LED power indicator. If you see it flash, or light dimly, the switch is bad.
Read the manual-- the unit may have a reset function you can access, or require a tape in it to power up. Hope these help.
Nov 18, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Canon ZR70MC Mini DV Digital Camcorder just stops
Hello, Sorry to hear that your Canon ZR70MC is not functioning. It would be our pleasure to assist you in being able to capture your once in a lifetime memories again. What is the estimated purchase date of the camcorder? If it is still under warranty the repair will most likely not cost you anything. Camcorder Repair http://www.precisioncamera.com/
Sep 08, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Machine just shut off when opening the cassette door. Locked up!!
look for a tiny pinhole and insert a pin while powered up to reset the device
May 27, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Canon ZR70MC Mini DV Digital Camcorder Logo
195 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
