Question about Maxtor Hard Drive
Growling, squealing noise on start up. Then it usually goes away. But sometimes it remains less noisy when running, sometimes goes away all together.
  • 59 Answers
Start by running a checkdisk on your drive. This can be done by opening my computer, right click on your harddrive, typically c:, and then properties. In the window, click tools and under error-checking, click check now.
Or, you can open start and click run, then type chkdsk.
Maxtor also offers a few tools to check for bad sectors on your drive, as well as the Ultimate Boot CD has some tools, found at ultimatebootcd.com.
Posted on Apr 16, 2009
Have a 2007 ford focus station wagon SE, makes a squealing noise by the pulleys and belt. When running still makes noise and when you turn on A/C the steering get really hard to maneuver.
Hey!
That look you problems with pulleys,holding the serpentine belt
Get oils spray into it,than you can see.Make the prove one at the time.
Start the motor and see squishing noisy goes away
Even do it in the AC motor pulley
Note:Do not forget change the serpentine belt
Jul 03, 2017 | Ford Focus Cars & Trucks
Bear tracker squealing noise when trying to start after running it goes away help please it sat for a year before got rear end fixed
Joe, do you mean a bearing track?
If so, a bearing -or track - usually makes a grinding or knocking noise, not a squealing noise.
If a car stands for a long time the brake rotors can corrode a bit and the pads can stick. Sometimes, when the car is first used after standing, you may hear a rubbing or squealing noise from the wheel. That's the pads sticking to a rusty rotor. The noise may wear off after a few miles when the pads 'polish' the corrosion off the rotor.
The other thing that causes squealing from a wheel are the brake shims. Try cleaning things first.
Mar 14, 2016 | Cars & Trucks
2005 mazda 3 manual trans 2.3L, when youre driving the car with windows rolled up and any gear change or speed you can hear a constant growling noise like two gears meshing together, was told it was warped...
Sounds like bearings to me. Jack car up and check for play. may be hard to detect. May only be on one side. car is kind of new to have bearings going out. That it is quiet on turns is usually a dead giveaway, but usually only gets quiet when turning a certain direction and not the other.
Sep 26, 2010 | 2005 Mazda 3
Intermittent - sounds like a cat caught under the
From what you have described I believe what you have is intermittent belt squeal in the serpentine belt. These tend to squeal in cold and damp weather and usually the noise will typically dissipate once the belt warms up from friction and radiated engine heat. (This is not always the case however).
You should check the belt for age and wear and, if in doubt, replace it as these are quite inexpensive items which need periodic replacement in any event. Also make sure the current belt - and any replacement - is properly aligned on the pulleys.
If you have no record of when the belt was last changed I would replace it even if it looks ok. These are easy and quick for an experienced person to replace.
Often when you replace the serpentine belt the squeal will disappear but return again as the new belt "wears in".
There are some temporary fixes for noisy belts which sometimes work (such as removing it and lightly spraying the belt with "Belt Grip"). There are also 1 or 2 others but I would not recommend them.
Dec 06, 2009 | 1995 Jeep Grand Cherokee
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Squealing Noise from GE DBSR453GBOWW
front drum bearing and guides
Mar 16, 2009 | GE Dryers
Loud noise at end of Draining
If your dishwasher seems noisy, check these:
1. Water-inlet valve
2. Motor
3 Heater fan
4. Pump
Water-inlet valve
An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor
If it's the motor that's noisy, either of these may be the "culprit:"
As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan
If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump
Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
good luck
thanks for using FixYa
Jan 28, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
GLD6200 NOISY
The sound is almost always caused by a worn docking cone “O” ring on the main conduit. When the docking cone “O” ring wears, the mid level spray arm conduit is no longer constrained and it can vibrate against the docking cone, making the “growling” or vibrating sound. Use a plastic wire tie to quickly verify if the growling noise is coming from a worn “O” ring. Snug the mid
spray arm coundit against the upper rack with the plastic wire tie. Run the dishwasher. If the noise goes away, you have verified the presence of a worn “O” ring. Remove the wire tie when the test is completed.
The recommended repair for this problem is to replace the WD12X10059 (titanium) or WD12X10121 (grey) docking cone. These parts supercede to the full main conduit. It is not necessary to replace the full main conduit for this problem. Remove the docking cones from both the existing and new main conduits. Install the docking cone removed from the new
main conduit on the existing conduit still installed in the dishwasher.
Oct 25, 2007 | GE 24 in. GLD6200L Built-in Dishwasher
Maxtor Hard Drive Logo
100 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
