Question about Kenmore Elite HE4 Electric Dryer
I need to clean out the dryer duct and inside.
I'm having a hard time get the control panel off of the front load dryer. Is there a clip or does it pop out or up. I don't want to break the panel. Please help?
You just need to remove the two small bolts at each bottom corner of the panel.
Posted on Sep 21, 2007
How do I remove front panel so I can vacuum the excess lint inside the dryer?
remove 4 philips head screws inside door opening. twist the top narrow part of the front panel to release itfrom clips, tip panel out towards you and lift off. there are 6 5/16 screws on the sides of the bulkhead that needto be removed(there are 8 but 2 of them can be left in). lift the top slightly and you can remove the front bulkhead and clean the duct area.
Dec 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do I clean the lint from the dryer past the lint trap?
you need to unplug the dryer,then with a putty knife stick it in between the top panel and the front panel and there are clips one on each side that you release with the putty knife and remove the front panel or you could have two 5/16 inch screws on the bottom of the front panel but i believe your model has the clips,when you remove the front panel you need to clean out the duct that the lint filter slides into,vac out the inside cabinet where the motor is,put it back together then pull out the dryer and remove the vent line from the rear,if it's a long run to the outside you can stick a leaf blower inside the vent line and blow all the lint out to the outside hood,before you blow it out go outside and make sure the hood is clear then blow out the line,
Oct 30, 2010 | Maytag HYE3658AY Electric Dryer
HOW TO CLEAN THE DUCT BECUASE A TISSUE GOT STRUCK IN IT
if the filter is on top,unplug the dryer,pull out the lint filter and remove the two phillips screws in front of the filter on the top panel.pull out the dryer and remove the vent line and the back panel of the dryer.on the left side you'll see the duct that the lint filter slides into,there are four screws holding it on plus the two phillips screws you already removed,it might be easier to pop the top of dryer so you can lift the duct up to remove it,with a screw driver pop the top panel up by sticking the screw driver into the space between the front and top panel around two inches from each side,this is how you get inside the dryer,use the screw driver to separate the door switch plug and remove the two 5/16 inch screws one on each side of inside front panel,pull up on left then right side of panel and you can remove the front panel to vac out the inside of dryer,now remove and clean out the duct,next if your vent line is a long run from the dryer to the outside i use a leaf blower to blow out the line,you should do this once a year so you don't have a fire and the dryer will run like it should,your clothes will dry on time
Apr 18, 2010 | Kenmore 63942 Dryer
Kenmore Model 110.68422700; the dryer cycles all the settings
when was the last time you cleaned out the dryer?you should clean the dryer once a year anyway so try this,unplug the dryer,remove the lint filter,take out the 2 phillips screws in front of the filter on the top panel.pull out the dryer,remove the vent line from the back of dryer and remove the back panel.on the left side you'll see the duct that the filter slides down into,take out the 4 screws that hold it in and remove it and clean it out,vac off the back of dryer,if you have a shop vac put it on blow and blow out the blower wheel and the heater and blow out the duct to get it clean.if the vent line is long i use a leaf blower to blow out the vent line,go outside first and make sure the duct outside is not blocked with any lint or anything and make sure the flapper opens freely.put it back together,except for the 2 phillips screws on top,with a screw driver pop up the top panel,there are 2 clips on each side that locks the top panel to the frame,just stick the screw driver in between the front panel and the top panel and pop it up,you'll see 2 5/16 screws one on each side around 4 inches down from the top on the inside,remove them and disconnect the door switch harness,use a screw driver to stick in between the harness to pull it apart to make it easier to get it apart,pull up on the front panel one side at a time and remove the front panel,vac out the inside of dryer,blow off the motor and blow all the lint from the back to the front so you don't have to pull the drum,if you know how to reinstall the belt take out the drum,the timer moves when the heat shuts down but if the dryer is loaded with lint the heater will not run correctly because of bad air movement and the clothes won't dry so try this first and let me know what happens
Apr 01, 2010 | Kenmore Dryers
Maytag performa Keeps blowing Thermal Fuse. Vents are clean. Cleaned entire system. Seems to heat up as soon as dryer cuts off.Changed control thermostat as well. Can get one load and replace fuse.
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
Mar 19, 2010 | Maytag PYE2300AY Electric Dryer
How do you take the access panel off the bottom of the dryer to clean out the build up. There are two clips at the top of the panel below the door section. How can I remove the access/kick panel to clean...
Insert a putty knife about two inches in from each side (where the toe panel top seam meets the dryer front) to release the clips. With the clips released, the toe panel will open from the top and can be removed. You may want to also remove the air blower cover and clean inside the duct chute and the squirrel cage motor to ensure it is also free of lint. You will need to remove the lint filter BEFORE removing the cover or you will have difficulty removing it. If you have any questions, please post back with your MODEL NUMBER. I hope this helps you.
NOTE: Make sure you UNPLUG the dryer PRIOR to servicing anything inside the cabinet. Dangerous voltage is still present even with the unit shut off.
Mar 16, 2010 | Dryers
How to secure gas dryer bottom panel to old Whirpool dryer
Should be two metal clips on bottom front of dryer that the panel slides onto and two clips on top of front panel that click in.
Here is a pic of the clip that goes on the bottom of the front of dryer in which the panel slides on.
http://www.partselect.com/PartDetail.aspx?Inventory=334839&SourceCode=1
You can see how the panel is removed in this video:
http://www.youtube.com/watch?v=jDUXsc_vapQ
Jan 12, 2010 | Whirlpool Dryers
Amana NEW7200TW (1 year old) runs, but stopped heating.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 30, 2009 | Amana NED7200TW Electric Dryer
How do I take the front lower panel off the dryer?
There should be retaining clips along the upper seam of the panel where it meets the front panel, about 2 inches in from each side. Take a putty knife and insert to depress the clip, while pulling out on the panel at the same time. Release the opposite side in the same manner. The panel will open from the top and be removed.
You mentioned poor heating and longer dry times. The following link will give you some good advice on how to resolve this issue:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Most dryer heat related problems are caused by poorly installed vent ducting, kinked, vent hoses, or clogs. You are right to suspect your dryer may need a good cleaning, but make sure you thoroughly inspect the vent ducting as well, though. If there are large accumulations of lint inside your dryer, there is a clog somewhere. If you have any questions, please let me know. I hope this helps you.
Apr 30, 2009 | Kenmore Dryers
Replacing Belt on Jenn Air CLothes dryer
1. Disconnect power
2.Use Putty knife and push in to release two spring catches between top and front panel about 3 inches from either side. Top then lifts up. Undo two hex screws on either side of side panels close to top. Front panel then tilts forward. Un-clip door switch and wiring harness before lifting off front panel. If belt is broken, drum should lift off by slowly raising front of drum to disengage wheels at rear of drum.
3. clean accumulated lint from inside fan housing and duct work on front panel as well as from total inside of dryer base before placing new belt around drum, smooth side up before carefully replacing drum in place to engage two wheels at rear of drum.
4. reaching left hand under drum, raise spring loaded idler arm and place ribbed side of belt around pulley on end of motor with right hand before releasing idler arm to provide tension on belt.
5. Place front panel on bottom clips and reengage door switch wiring harness before reattaching hex screws at top of side panels.
6. drop top pannel of unit in place to reengage spring clips before reconnecting power
Dec 24, 2007 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
