Question about Nostalgia Electrics Hot Dog Grill Roller with Griddle
How does this machine heat the hot dogs, is it gas or electric. I'm considering purchasing this machine and cannot locate where to inquire about this item.
  • 19,396 Answers
Posted on Apr 16, 2009
  • 832 Answers
What you want is an electrically operated hot dog roller. You can get
this from a food equipment stores in your area.
Posted on Sep 22, 2009
Gas dryer. Samsung DV42H5200GP 7.5 Cu. Ft. Gas line connected, but not in on position. Is there a pilot to be lit? If so, where located?
No pilot...
Yours is a "hot surface" electric igniter ...
The link (below) should take you directly there...
(picture is just for viewing ... Retailer sales site)
Please be advised... gas appliances must be externally vented & installed in a manner as NOT TO THREATEN human life.
EVEN if you are having a HIGHLY QUALIFIED technician install, inspect & operate your equipment... The instructions should be completely read & understood by EVERY USER.
ADDITIONALLY it would be VERY WISE to consider getting a carbon-monoxide detector ...
Like your life depends on it.. because it could...!!
Be safe.
http://www.appliancepartspros.com/samsung-heate-dc47-00022a-ap4211272.html
Dec 12, 2016 | Samsung 7.5 Cu Ft Capacity Platinum Gas...
What should I do in order to make sure my dog house stays cool in the summer?
In order to keep your dog's house cool during hot summer days, consider to do the following:
  • Place the dog house in the shade so it doesn't get too hot from the sun.
  • Make sure that the house is ventilated so warm air can come out.
  • If it gets really hot inside the house, you should put a fan to cool the house down or buy a small air conditioning unit made for dog houses.
  • Place a cooling mat on the ground of the house. This will help the dog to cool down during the hot summer days.
Oct 25, 2012 | Dogs
I just purchased a Maytag Neptune gas dryer, do I need to light a pilot if not what do I need to do to get it hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[[[]
Aug 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
No hot air coming into dryer-- Where is the heating element located PLEASE???
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 30, 2010 | Whirlpool LER4634J Electric Dryer
Adjitater is loose , can this be tightened up? heater not getting hot in cloths dryer
If its just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
As far as your dryer is concerned, if your dryer runs, but does NOT heat, the following two links explain how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back with your MODEL NUMBERS (you didn't post a brand name or model for the dryer) and let me know. I hope this is helpful to you.
May 02, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
How long do you put hot dogs on the roller grill?
Once you have the rollers hot (10 min.) it should only take about ten minutes for the dogs to heat up... they are fully cooked so you anly have to get them hot, but you can let them on for a much longer time if you want too, like if you are selling them at a stand...
heatman101
Apr 29, 2010 | Nostalgia Electrics Hot Dog Grill Roller...
I have a gas dryer that has a bad thermostst how can it be replaced Do 110 dryers use more electricity than the 220, are they safe
The thermostat is located in the back, behind the back panel and mouted on the air discharge from the drum before it entered the blower that blows it out via the vent. They are normally snap-disc style thermostats and can be ordered from sears parts direct online or purchased at most sears appliance parts stores. Gas dryers also have at least two over-temperature devices to prevent an overheat condition that may lead to a fire. One is normally a snap-disc thermostat (some with a manual reset) and the second is usually a thermal-fuse that must be replaced...not reset. 110 gas dryers use a lot less electricity than 220 electric dryers since all they have to do is turn the drum and blow the air (heat comes from a gas flame) where the 220-volt electrics have electric heating elements that comsume large amounts of power. Yes, I would consider then safe as long as they are vented correctly.
Nov 27, 2009 | Kenmore 63942 Dryer
Abbreviation definitions.
Economy Mode = EM
Auxelary Mode = AUX
in em mode heat pump does most of the work in aux either an electric heating element is used or gas depending on if it is gas or all electric
Oct 16, 2009 | Ruud Central System Air Conditioner
Lighting my pilot
If this is old enough to have an actual gas pilot it will have a thing called a thermocouple. The pilot flame burns around this thermocouple to keep it hot. The thermocouple must be hot from being in the burning gas or it will turn the gas off to the pilot. Yeah, it's kind of a viscious circle isn't it? This is where a propane torch comes in handy, but you might do this with one of those butane matches with the long neck. Apply a flame to the thermocouple for 30 seconds or so. When the thermocouple gets hot enough the pilot will self-sustain. Be sure it is the thermocouple it is you are heating up. It is at the end of a rather thin, what looks like a wire but is actually a wire inside of a thin tube. (still looks like a wire). Might be described as looking like a hot dog on a stick in miniature form. the hot dog part being about 1/8 inch by 1 inch. and is in a bracket.
Aug 10, 2008 | Tappan 24 in. Freestanding Gas Range...
Nostalgia Electrics Hot Dog Grill Roller with Griddle Logo
362 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Robert
Wayne Fellows
Wayne Fellows
Christopher Smith
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
