Question about Brother P-Touch 1180 Label Printer
Can't peel off label backing-have short weak nails
How to peel off label backing. I have very short weak nails.
Most brother labels peel by gently folding the label in half the long way. No need to separate with your nails.
Posted on Apr 17, 2009
  • Gordon Gibson Jul 29, 2011
    You gotta be kidding! It's like pulling nails out with your fingernails! If your somewhat handicapped in your hands like shaky or short fingernails or older and can't see. You should wake up, you'll be there yourself someday.
How do I paint my finger nails perfectly?
use cellotape or inch tape wrap around nails and color the nails and peel off simple and cheap
Feb 23, 2015 | Health & Beauty
Can you use polish on top of the temptique nail repair
Temptique' Brush On Nail Repair is excellent for making weak nails harder and stronger...especially if you naturally have weak or thin nails.It Helps polish and designs last longer.
Mar 26, 2014 | Temptique 2 Pack of Brush-On Nail...
My nails are really soft and often peel. How can I improve the condition of them?
You can use cuticle oils or paraffin treatments to massage into the nail and this will help strengthen the nail.
Jan 10, 2013 | Health & Beauty
After doing my brisa gel nails I noticed the product separating from the tips. What did I do wrong?
If you have any trouble with your Brisa gel nails, there are several instances that may cause problems such as peeling and lifting. If the gel is allowed to touch the skin, cuticles, or sidewalls, peeling may occur. Peeling is also not uncommon if too thin a layer of gel has been applied. It is important to apply several thin layers to build up the strength and create an apex. Also, Brisa Bond must be cured under the UV light for 10 seconds or peeling may occur. Lifting may occur if you have not done a thorough preparation of the nails before applying the product.
Be sure to keep the gel in the pot away from the UV light. If uncapped pots are exposed to the light for long periods of time, the gel will turn hard and be unusable.
Brisa gel is hypoallergenic, but that doesn't mean that you won't be allergic to it. Being hypoallergenic simply means that a person is less likely to be sensitive to the product, because it doesn't contain some of the chemicals that other gel systems do.
Good Luck!
Mar 14, 2012 | Health & Beauty
Label peeling
Sometimes the peel bar gets worn out and isn't very sharp anymore (replace). This will affect the peeling. Also try increasing the printhead pressure with the printhead toggle.
Jun 03, 2009 | Zebra 105Se Thermal Printer
How to feed labels on zebra s4m
The issue that is causing the problem is when users tear off the label they are actually partially pulling on the next label causing it to peel away a little then when it feeds it will jam. Only reliable way to stop this is once the user prints tell them to press feed and feed 1 label through.
Mar 31, 2009 | Zebra S4M Thermal Label Printer
Label not discharging far enough out of the print head
Hi
Can you tell what the printer is and what the material spec is?
Regards
Bob
Jan 11, 2009 | Zebra 110PAX4 Thermal Label Printer Print...
AVery 9100
Also, what I did was to first back all of the labels out and back into the reel. Turn machine off, then back on. With the peel lever down, as mentioned above, begin to load the labels as shown. The light will blink and it will make a noise as it senses the label. It will begin to draw the label in and you need to make sure you create tension on the labels as they are being pulled in. I accidentally did this by holding pressure against the reel, and sure enough, the thing pulled the first label into place and quit frickin blinking!!! Labels printed fine afterwards!
Dec 31, 2008 | Avery 9100 Thermal Printer
Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Jul 30, 2008 | Zebra Stripe S600 Thermal Label Printer
Brother P-Touch 1180 Label Printer Logo
150 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
