Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral side by side refrigerator ,model sal2027gbb
Admiral side by side refrigerator ,model :sal2027gbb ice maker is not getting water
  • popo502 Apr 17, 2009
    I have switch over the valves and the valve is working ,what should be the next step.
  • 121 Answers
Icemaker water valve is bad check to see if you can tell if the unit is turning
Posted on Apr 17, 2009
Admiral Maytag side by side model LSD2615HEW not getting cold. Fan runs. Clicks from the back every few minutes or so.
Its issue with compressor or the problem with defrost timer.It clicking to set the defrost cycle,but not actually working.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Admiral 26 cu. ft. Side-By-Side...
Ice maker leaking after filling
Most likely the=> 67005154 Dual Waater Control Valve
found on the rear of your refrigerator and down near the floor is becoming worn out and not closing all the way. Are the ice cubes also beginning to stick together? I need you to watch this problem to see if it becomes worse and gets stuck open allowing a lot of water into ice maker. The ice maker determines how much water flows to ice maker about 7 seconds time but if mechanically defective it will not close all the way even when off. I will stick with a solution but will meed you to respond, Thank You, Sea Breeze
Dec 10, 2012 | Admiral 26 cu. ft. Side-By-Side...
I have an admiral sal2027gbb and the alarm keeps sounding. there is ice building up on the back of the freezer. we have dad the sensor replaced and heating element but has not solved the problem. can you...
Could be the temp is set too low that would cause the ice build-up, thus causing the alarm to set off. Try defrosting the freezer, and run the fridge again.
Feb 03, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice maker stoped
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
yy
Sep 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
My ice maker quit making ice. I've had this
Check for broken gear or cam in the ice maker module. You can repair them but it might be easier to replace. If your gear and cam are good it pobably is something else that's wrong.
Jul 05, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral Refrigerator Ice Maker
pull your icemaker tube out and see if it is frozen with ice,let me know-mike
Sep 22, 2008 | Admiral Refrigerators
Problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
Mar 30, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral Ice maker water filter, which one?
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Jan 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
234 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
