Question about Alpine CDA-9885 CD Player
Interface Problems Had the CDA-9885 installed a few days ago, and I thought it just took getting used to, but it seems the 'rotary encoder' is extremely touchy. I go to change the volume, by turning the 'rotary encoder' or the nob, and it sometimes does it, or it will cycle through all the bass/treble/fade things. It's about 50/50 chance of working. Then 'loudness' toggles itself on/off more times than not when I try to change volume. All the while this thing beeps occasionally, and most times after a beep happens, none of the buttons work, like the deck goes into lock down mode. Only the 'rotary encoder' will work, usually cycling the audio settings, but I have no idea what makes all the buttons work or not. I do mean all the buttons, power/band/func./(>/=) etc. Is it me or is it the deck?
  • Anonymous Mar 10, 2009
    I started taking out my face plate every night because it seems like every other car gets broken into around me. After about a month of this my stereo shuts down. It wont let me push any buttons (not even power) and the volume only works sometimes. If I do lightly or roughly change the volume it freaks out and switches from bass/volume/defeat/and other sound options while beeping. I know this problem has to do with the face plate connecting to the stereo itself. Please help I'm a broke college kid who can't aford an expensive fix and am road tripping in my truck across the country and would love my radio to work!
If you're pressing on the "rotary encoder", then it's you. But if you're not and instead you're just turning it without pressing, you may have a defective unit. Try literally pulling on the thing while turning it. If that avoids triggering the other functions then either you'll have to get used to being gentle, or you need to take it back or send it to Alpine (again, probably just the front faceplate unit needs work...not the whole radio).
Posted on Oct 09, 2007
Setting up ipod to CDA-9885R
The ipod cable plugs into the rear of the stereo. Here is a link to the installation manual:
http://vault.alpine-usa.com/products/documents/CDA-9885%20OM.PDF
Aug 23, 2012 | Alpine CDA-9885 CD Player
How do i set the clock for this cd player
You can get the manual on the link below. Page 6
http://a248.e.akamai.net/pix.crutchfield.com/manuals/500/500cda9851.pdf
1 Press MENU to select SETUP.
2 Press or > to select the CLOCK mode.
3 Turn the Rotary encoder to adjust the hours.
4 When the hour has been adjusted, press the
Rotary encoder.
5 Turn the Rotary encoder to adjust the minutes.
6 When the minute has been adjusted, press the
Rotary encoder.
7 When the setting has been completed, press
MENU to select RETURN.
The unit returns to normal mode.
Pressing and holding MENU for at least 2 seconds will
return to normal mode.
Feb 06, 2011 | Alpine CDA-9851 CD Player
THE STEREO CODE FOR ASN ALPINE CDA 9855? HOW OR WHERE DO i GET IT??
there is no code for an alpine cda 9885. what seems to be the problem with the radio?
Jan 03, 2011 | Alpine CDA-9885 CD Player
Set clock on a alpine cda-9805. I can change hr not min
Heree is how to set the time on the radio.
1 In the Clock priority mode, press and hold the DISP/
TITLE button for at least 3 seconds while the time is
displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours while the
time indication is blinking.
3 When the hour has been adjusted, press the Rotary
encoder.
4 Turn the Rotary encoder to adjust the minutes while
the time indication is blinking. The time is automatically
set 5 seconds after the minute adjustment. The time
can also be manually set by pressing the Rotary
encoder
If you need the manual is on the link below page 6 tells you how.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9805.PDF
Good Luck
Nov 06, 2010 | Alpine CDA-9805 CD Player
How do you change the time on the clock? Don't
This is from Page 7 of the manual available on Alpine's site:
moz-screenshot-1.pnghttp://vault.alpine-usa.com/products/documents/OM_CDA-9884.PDF
Setting the Time
1. Press and hold F/SETUP for at least 2 seconds to activate the SETUP selection mode.
2. Turn the Rotary Encoder to select CLOCK ADJUST,
and then press "magnifying glass"/ENT
3. Turn the Rotary Encoder to set hour.
4. Press "magnifying glass"/ENT
5. Repeat steps 3 and 4 above to set minute.
6. Press and hold F/SETUP for at least 2 seconds to return to normal mode.
I hope that helps.
May 21, 2010 | Alpine CDA-9885 CD Player
How do we set the clock
TITLE
encoder
encoder
May 16, 2010 | Alpine CDA-9825 CD Player
How do i get my Alpine CDA 9885 head unit out to fit a sub???
Remove the face, and trimring plastic.
There are slots on either side that you put the Alpine unlocking keys into (came with your headunit new) then slide the chassis out.
If you don't have keys - you can use a small allen wrench - or buy them at best buy etc.
A local alpine dealer will probably let you borrow his keys as a good business practice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 23, 2009 | Alpine CDA-9885 CD Player
Alpine CDA-9885 intermittent problems
you can try removing the faceplate and cleaning the copper contacts with a pencil eraser. This might help
Jun 15, 2009 | Alpine CDA-9885 CD Player
Manual for cda 9885 r
http://www.alpine-europe.com/index.php?id=915&L=&manualsearch=CDA-9885R
Feb 02, 2009 | Alpine CDA-9885 CD Player
Alpine CDA-9885 CD Player Logo
109 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
