Question about Ryobi Cultivator
Gas lines Replacing gas lines on my ryobi 410r. I cant rember witch line goes where to the carb. does the pluge line go on top or bottom of carb?
  • lockridge99 May 05, 2009
    all the lines fell off from old age. done know where they go.
4 Suggested Answers
  • 1632 Answers
SOURCE: unable to start Ryobi 410r cultivator
After starting close the choke , push the lever back in
Vitally
Posted on Jun 02, 2009
bbreton
  • 437 Answers
SOURCE: needs new primer
You are searching for part number 181558. It is a snap in primer bulb with a piece of fuel line.
Posted on Oct 02, 2009
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
Craftman trimmers has two gas lines wich one goes to the primmer the one with the filter or the thine one
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 09, 2012 | Garden
Which fuel hose go to the top of the carb and which to the bottom? Which lines from the prime bulb go where? Replacing the bulb and all fuel lines.
Hi ibcasady...
The bottom fuel tank line runs to the bottom connection, the top fuel tank line runs to the top...
Test it to make sure that is the right direction, and that the carburetor is being primed with fuel...if not reverse the hoses.
Free Answer...Please take time to rate me
Jun 05, 2011 | Ryobi Garden
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacing broken gaslines... were do they go?
the primer bulb draws gas through the carb 'C' and back to the tank'T' leaving a small amount of fresh gas in the carb.to replace the lines from filter to carb & bulb to tank,you may have to remove handle & split the housing halves to find where lines enter tank.look in tank W/ a flashlight.to replace lines cut new line on an angle,feed a piece of # 14 copper wire through hole from inside tank.slide new line over wire,the wire will help align fuel line with hole.use needle-nose pliers to push line into tank,& to pull it through once you can see it.cut off end of hose you beat up with pliers.push filter on hose to carb.drop it back in tank."T' line is the return.dosn't matter which line is through top or bottom hole.
Sep 21, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Where do I connect the fuel lines on my ryobi weedeater?
I have Ryobi775r string trimmer with walbro WT526 carb. The fuel lines connect 3 parts eg. gas tank, bulb (mine is a separate bulb not part of carb.) and the carb. The bulb has 2 fittings- a short and a long one. The carb also has 2 fittings- one on top (vertcle) and one on the bottom (L shape). The gas tank has two holes in the bottom one for over flow line and the other for fuel inlet to the carb. This has a filter in the gas tank. Now the connections- connect the long fitting on bulb to the tank. this is the overflow. Connect the short fittin on bulb to the carb top (verticle) fitting. Connect the fuel line (with filter - it is in the tank) streight to the L fitting on the bottom of the carb. Make sure the fuel lines are of right diameter. Too big-and you will have leaks. You are done connecting the fuel lines. just for info. the bulb is there just to pull a vavcume in carb so that the fuel is sucked into the carb and is present there when you start the engine. Hope it helps. Good luck.
Jul 07, 2009 | Ryobi Garden
There are two hose/line openings in the gas tank of my Ryobi 410r cultivator. Where and which do these two lines go to? Which of them goes to the primer bulb? Also, there are two lines to/from the primer...
IT SOUNDS LIKE A TWO CYCLE ENGINE TO ME. THE HOSE GOING TO THE PRIMER BULB GOES TO THE HOSE THAT SITS ON THE TOP OF THE TANK AND DOEST GO IN FAR AT ALL AND IS USUALLY THE BACK. THE OTHER HOSE GOES IN THE NID PART OF THE TANK OR THE PART THAT THE GAS IS AT ITS HIGHEST POINT IN THE TANK WHEN THE UNIT IS IN THE POSITION MOST LIKE IT IS WHEN IN USE USUALLY THIS HOSE HAS A SMALL FILTER IN THE TANK. THIS SYSTEM OPERATES ON PRESSURE. WHEN YOU PUMP THAT BULB, IT PRESURIZES THE TANK FORCING GAS UP THROUGH THE OTHER LINE TO THE CARB. IF YOU ARE SYING THERE IS A 3RD HOSE HMMM, THAT PROBABLY GOES TO THE MIDDLE PART OF THE CARB
REGARDS
Jun 30, 2009 | Ryobi Cultivator
Need Replacement Gas Line for Ryobi 410r
They have the parts your looking for at www.lawnmowerpartstore.com
Apr 12, 2009 | Ryobi Cultivator
Ryobi 768r fuel line
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
Mar 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi Cultivator Logo
212 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
