Windows Vista doesn't recognize cable
I purchased a usb to serial cable about 3 years ago from radio shack. Now I am installing it onto a new laptop because my previous laptop was stolen. The old laptop was Windows XP and the cable worked fine. The new laptop is Windows Vista and it will not recognize the software. Help me...please!
    President:
  • 1,996 Answers
XP & Vista require different drivers to run hardware devices.
Visit the Vista compatibility site to determine if your hardware is compatible, by clicking here,
or visit the manufacturer's website to see if there are updated drivers and firmware available for Vista that you can download and install.
Another possibility is to visit Windows Update and run a custom scan with the cable attached and see if you are offered a hardware update for your system that would make it work, but this seems unlikely in the case of a cable...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 16, 2009
Trying to connect a USB to the serial port of a Bernina Sewing Machine (Bernina 170). Has been working for a couple of years and has stopped all of a sudden. Does not work on and XP PC, Vista or win 7....
The Dynex adapter does not have any numbers on it. It was the one that is only about a foot in length and has a square center piece that houses the conversion electronics. Standard 9 pin RS-232 male plug on one end and the standard USB plug on the other end. I purchased it within the last month at BestBuy here in Austin TX.
Oct 28, 2010 | Bernina Artista 170
I have USB to USB data Transfer cable, lost the installation CD
Can't you use the cable with windows transfer wizard.Your PC should recognise the cable if it has plug an 'play.
Jul 12, 2010 | Computers & Internet
I own a Quantum XL 6000. I need a patch for my sew ware conversion software to download onto my new laptop which uses windows vista. Where can I find this patch?
GO TO USA CABLES AND ORDER #CUSB-232A WHICH IS A 3' USB TO SERIAL ADAPTER INSTALL IT ON YOUR LAPTOP AND IT WILL WORK WITH VISTA, THIS IS THE CABLE THAT SINGER RECOMMENDS TO USE, THEN AFTER IT IS INSTALLED PLUG IT INTO THE NULL MODEM CABLE AND IT SHOULD READ THE SEW WARE CONVERSION. I HAVE TRIED SEVERAL OTHERS AND THIS IS THE ONLY ONE I CAN GET TO WORK WITH VISTA.
Apr 25, 2010 | Singer Quantum XL-6000 Computerized Sewing...
I purchased my Microtek ScanMaker 3800 many years ago. I still have the installation CD. Recently I purchased an HP laptop running Vista. My question: is it all right to plug in the scanner directly...
First connect your scanner to computer with usb cable.
Then insert disk in rom then install driver and software from disk.
It is not matter that first you connect scanner or install driver but if you connect scanner first your computer recognized it then you can install driver from disk.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 13, 2010 | Microtek Computers & Internet
Lp 2844 will not work with my new laptop
You need a piece of software to create a Virtual com port, make sure you have the comms set correctly 9600, n, 8, 1 and print to that port, you will find it clearly marked in Device Manager. You can get a parallel to USB cable then you can use your driver set to LPT1
Nov 05, 2009 | Zebra LP 2844 Thermal Printer
Customiser 2000 will not connect to a laptop as it has a 9 pin serial port (female) and the laptops have a 15 pin (female) I have bought 2 different cables but none work it just says serial port did not...
Are you using a USB-to-serial adapter?
I *think* what the problem might be is that the COM port's not been set in Customizer. Within either of the Easy/Customizer apps, go to ScanCard>Communication Settings ... you'll open up a dialog box within which you can set which COM port your cable's going to use.
If you're compie savvy, you can go to the Windows Start button on Task bar>Control Panel>System>Device Manager>COM ports and SEE which COM port your cable's using.
But until your software knows what COM port your cable's using it will NOT recognize that you have one installed.
Please let me know if this doesn't help! Or if there's anything I can help with!! :)
Aug 01, 2009 | Janome Memory Craft 9000 Computerized...
Radio Shack Serial to USB Cable
you'll need vista drivers for that which radio shack didnt make for my cable so i replaced it
Jun 08, 2009 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
Pfaff 7570 connection to new XP laptop
In this FAQ list (from PFAFF web) you find 100 times the same question and answer:
H402 My new computer does not have any serial COM ports, so how does it communicate with my Pfaff creative 7570?
You will need to obtain a USB Serial Adapter, which adds a serial port to your computer by plugging it into a USB port. Suitable adapters can be obtained from Belkin [http://www.belkin.com] and Keyspan [http://www.keyspan.com].
The following USB Serial Adapters are known to work with the Pfaff creative 7570:
• Belkin F5U103
• Keyspan USA-19QW
Please note that the Belkin F5U109 is listed as working with the Pfaff creative 2140/2144 (FAQ #H405), but it does not work the Pfaff creative 7570.
Jan 06, 2009 | PfaFF Creative 7570
Gigaware USB to Serial Cable software
No need for disc, don't worry.
Radio Shack/Gigaware 26-949 USB to Serial Cable drivers (32/64bit) can be found at driverupdate us
I hope I have helped you...
Take a look, and enjoy
May 07, 2008 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
Radio shack Pro-433
Look at www.radioreference.com This is the most complete scanner site on the web. Just register and then search the forums for what you need.
Jan 18, 2008 | Radio Communications
Computers & Internet Logo
David Payne
David Payne
