Question about SanDisk Sansa e200 MP3 Player
Use rhapsody for the trial period and now My SanDisk Sansa e200 won't acknowledge any downloads on my e200 since I didn't sign up for rhapsody. How can I get my e200 to allow download from somewhere other than rhapsody?
  • 626 Answers
If you didnt delete the music from your trial subscription with Rhapsody, they are still on the device, taking up space. Your device will allow any type of music to be transferred, it doesnt have to be specifically from Rhapsody. Best idea is to "format" the device to remove everything and try transferring the music onto the device. Connect the device and go to My Computer>Device Name, then right click on the device and select format. This will erase everything. If you are not able to format the device, change the mode, then try again. Device>Settings>mode or USB Mode. Reply if you have more problems. Best of Luck.
Posted on Sep 16, 2007
SOURCE:
I erased some things i didn't think i would need from the mp3 player (photo folder, etc.) and now when it turns on it just says "Load main image failed, switch to recovery mode"
STEP 1: Soft Reset
Simply press and hold the power button for 20 seconds. The soft reset would refresh the player. After doing the soft reset, try to turn on the player once more. If this didn't resolve your issue continue to step 2.
STEP 2: Firmware Update
Firmware controls the functions of your device (how your device operates). In cases where the product does not perform as intended, the update fixes the issue by replacing the current firmware with the latest enhanced version.
Please be reminded that for your player to work properly you need to meet the requirements below.
- Windows XP SP2 or higher
- Windows Media Player 10 or 11
To Download the Sansa Firmware Updater, you may copy and paste this link to the address bar of your web browser:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
To Know More on Using the Sansa Firmware Updater:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=306
If you encounter any issues with the Sansa Firmware Updater, we can try to use the Manual Firmware Update.
There are three versions of the Sansa e200 - Version 1, Version 2, and Rhapsody. This can be found by going over to "Settings" if you found "format" then you have a "v2" or look at the back of your player and check the exact model number under the "CE" logo it should say "model:e200" for Version 1; "model:e200 V2" for Version 2; and "model:e200R" for Rhapsody Version. Make sure that you choose the correct firmware version for your device as updating it using the wrong firmware version may render your device useless.
E200 Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=15209
E200V2 Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=13548
E200R Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200R&thread.id=2280
Dec 25, 2010 | SanDisk Sansa e200 MP3 Player
My sansa e250 having video option, but it not supot any video file to play on the player.
When your operating system on the computer is Windows:
Run the Sansa Firmware Updater to get the Sansa Media Converter: http://kb.sandisk.com/app/answers/detail/a_id/101/related/1
When your operating system on your computer is Mac, or when you want to update manually:
go to the Sansa forum: http://forums.sandisk.com/sansa/board?board.id=e200
note
Only when you have the e200 series version 2 player, videos can be viewed from the microSD card.
Accessing the microSD card:
http://kb.sandisk.com/app/answers/detail/a_id/167
Highest capacity of the microSD card:
Verify the version of the player. To check, go to Settings > Info.
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
Differences between e200 version 1, 2 and Rhapsody player:
http://kb.sandisk.com/app/answers/detail/a_id/193
For supported files, see:
http://kb.sandisk.com/app/answers/detail/a_id/21
and
http://kb.sandisk.com/app/answers/detail/a_id/32
Aug 13, 2010 | SanDisk Sansa e250 MP3 Player
I have sansae200 when i copy one video clip it says it is not comeing and picturs also not comeing
How to handle pics and videos on the Sansa e200, see next link:
http://kb.sandisk.com/app/answers/detail/a_id/564/kw/media%20converter/r_id/101834
These are videos showing how to add pics and videos on the player, using the Sansa Media Converter.
Download the Sansa Media Converter:
http://mp3support.sandisk.com/sansa/SMC
Allow the download when blocked, to start downloading.
Guides for the e200 series:
e200v1:
http://mp3support.sandisk.com/downloads/um/e200v1_userguide_en.pdf
e200v2:
http://mp3support.sandisk.com/downloads/um/e200v2_userguide_en.pdf
e200r Rhapsody:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Nov 12, 2009 | SanDisk Sansa e200 MP3 Player
How can you tell if it is a version 1 or 2?
Sansa e200 series has 3 not interchangeable versions of firmware:
  • version 1: e200, firmware starts with v1.xx.xxx
  • version 2: e200v2, firmware starts with v3.xx.xxx
  • version rhapsody: e200r, firmware starts with v1.xx.xxx
Site for the difference between these versions:
The exact type should be on the back of the player: model e280R.
For the rhapsody there is only 1 firmware available.
The zip file can be downloaded here:
http://mp3support.sandisk.com/firmware/rhapsody-1.0.2.165.zip
When another firmware is needed, go to the download firmware wizard on next page and select your model:
http://www.sandisk.com/sandisk-support/driver-download-wizard.aspx
Sep 25, 2009 | SanDisk Sansa E280 MP3 Player
PC doesnt recognise my e250 mp3 player
Get the software from Sandisk's website - e200 series Support - get country-specfic software - are you in a country that bans music download services? Contact Rhapsody support, or go to their country-specific page for the answer to that one
Jun 11, 2008 | SanDisk Sansa e200 MP3 Player
Vista not compatible with rhapsody.
I use Rhapsody with Vista. You need to go to Rhapsody's website (or Best Buy Digital Music Store, which runs the same software) and download the updated version, which will work just fine.
Purchased music from iTunes can be put on Sansa players as well when you set-up Rhapsody to manage your music. Have the program detect your music library and then all you have to do is drag and drop to your MP3 player.
Apr 19, 2008 | SanDisk Sansa e200 MP3 Player
Music downloads
conect to your computer make a right click in the music folder you want to download and go to "send to" you will find the sansa in the list make a click over the sansa and you goit reapeat for each song or folder...good luck and rate this help.....
Dec 31, 2007 | SanDisk Sansa m240 MP3 Player
Sansa e200 resetting problem
The error message means that you have a different version.
Your device is annotated with an R or the word Rhapsody on the back. I have contacted FIXYA to add these models, but my words were unheard.
You will need to contact SanDisk for the Rhapsody version of the files to fix your problem.
SanDisk Technical Support 1-866-726-3475
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk e260R 4.0G - Getting rid of Rhapsody
I had the same problem. In the end I reformatted the e200. To reformat hook up to your pc and there should be a reformat option on the e200 icon.
Feb 07, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
75 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
