Power will not come on, but fuse is good
TV worked fine, I turned it off for the night and I usualy use the remote. this time I pushed the power switch and I think I pressed another switch. the power would not come on. the bottom blue light is on but no raster or sound. I took the cover off and the fuse was good. I am lost, it seem as if there was a code by pushing 2 buttoms at a time. any help would be appricated. john
  • john Hall Apr 16, 2009
    i will check the problems you suggested and will follow up with you.
    thank,
    john
    Problem Solver:
  • 5 Answers
I dont know about a code but i would check my 5 volt standby power supply voltage ,and depending on tv check all standby voltages with set pluged in only .if stand by voltages is good check for horiz drive at base of driver trans when you press the power button
Posted on Apr 16, 2009
My Samsung TV will not turn on.
Could be an open internal fuse or power supply failure
Apr 23, 2018 | Samsung Televison & Video
Toshiba 27D46 will not come on?
It may be a fuse. But something else may have blown the fuse. I would check the circuity of the power supply.
Oct 27, 2012 | Toshiba Televison & Video
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I turned the tv off the other night with the remote just like i always do got up next morning to turn it on it won't come on I have tried everything unplugging it pushing the power button on the tv instead...
Good day sir/maam, chances are you tv's switching power supply circuit has gone bad, you may try the following.
  1. open the back cover and locate the fuse, check if the thin wire is intact, (unplug the unit before opening the back cover) replace and test if the fuse blew up. test again.
  2. if the fuse is intact. replace the cover.
At this point. you have no choice but to call your dealer or repair man for service.
Oct 08, 2009 | Panasonic CT-36SX31 36" TV
My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Sep 24, 2009 | Toshiba 32A33 32" TV
Tv won't turn on
Was the power button from the main outlet(wall) kept in the ON (position)throughout the knight! i.e. switched off by the remote only? In that case a power surge druing the night could have fried some part of the TV circuit. In such case there are many fuses inside the TV which need to be checked out If the main tubes are gone kaput then better to replace the entire set......................sodeep
Sep 03, 2009 | Panasonic CT-32HXC14 32" TV
Tv won't turn on
yes but you have to open the tv
Mar 01, 2009 | Loewe Aconda ACO9303 30" TV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Hughes Remote works the satellite but not the TV
You have to push and hold down TV and Mute button (for 2 seconds at the same time), then release them at the same time, then push channel up until the TV turns off.  Be patient and continue channel up until the TV turns off.  When it turns off, then push TV again to lock the code.
You were doing fine, but missed to push channel up to fine the code.
Oct 25, 2007 | Hughes HRMC11 Remote Control
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
