Question about Garden
Im working on a briggs and stratton intek 6.5 it is starving out after pulling carb i found a small freeze plug in the bowl replace it back up in the top of fuel bowl. made new gaskets, cleared line into the tank. re assembled i have the same problem i started with frustrated in memphis shack
  • mcwestphal Apr 16, 2009
    I have a 6.5 that only runs for 4-6 seconds after priming, if I continue pushing the primer bulb it will keep running. I took off the airfilter. I removed the Bowl and 1st blew out the carb and bowl with compressed air, then with carb cleaner. I blew compressed air up the fuel line to the tank to make sure it wasn't obstructed. Put it all back together and it runs exactly as when I started!
  • james shack Apr 19, 2009
    sounds like you stood beside me while, working on this project. between carb and breather i smoothed mating sides with 800 grit
    and put them together wo any gasket. blew debris out w comp air
    put together it ran fine then it dropped a push rod on the intake rocker
    good winter project now huh ?
    thanks for all of your accurate help shack
  • 376 Answers
SOURCE: 7 hp craftsman Briggs/stratton lawmnower stalls
Your engine model # 128602 Type 0212-E1. Forget about ordering from Sears and paying shipping and waiting a week. Go to your local Briggs and Stratton dealer (most shops are) and buy part # 694395. Should cost about $3.00
Posted on May 31, 2009
  • 84 Answers
SOURCE: have a craftsman model :917.273621,
try the coil. the coil will produce the spark for the spark plug seeing as there is no battery, try replacing it with another of the same power.
Posted on Jun 24, 2009
rycgl
  • 1545 Answers
SOURCE: briggs and stratton 6.5 intek runs only if i keep
Drain the gas. Remove the aluminum float bowl on the carburetor. Dont lose the exterior washer. Clean the brass bolt very well that hold the bowl on...paying very close attention to the small holes near the top of the bolt. Use no metal objects to clean this brass bolt as it also functions as the main jet to the carburetor. If you clean it till it is nice and shiny and reinstall it (not TOO tight) then your fuel flow problem may be resolved. Hint: Install an inline fuel filter.
Posted on May 17, 2011
  • 640 Answers
SOURCE: will only run on fuel that is primed into carb.
Check for proper operation of the float and needle. If that is okay, clean the jets and all holes. if the main jet is blocked or the holes going into you will not get it to start.
Posted on Jul 31, 2011
richroth
  • 9472 Answers
SOURCE: Hi, Hello, I have a McCulloch
Take a look at the video below. I should answer your install questions.
Posted on Aug 26, 2011
22hp briggs and stratton intek v-twin model number 470577-0284-e1
to much fuel either the needle valve is stuck or the float is bad tear apart the carb acid dip and clean take float submerge in gas for 20 min pull out shake next to ear if you hear liquid inside its bad
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
24 hp briggs intek starving for fuel
Always check for jet. 90 percent of the time it is clogged. Remove the bowl and float and it is the center screw.
Jun 10, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Schematic for a Briggs & Stratton fuel pump & carbrater
most of the time you will not need new parts but the only parts out of the kit you will need is the needle valve (the part on the float) and the bowl gasket the first thing you do is take off the bowl then there is a pin that holds the float down pull it out with a pair of pliers i like one sided wire plyers then drop the carb and bowl in carb acid for 45 min i use chem dip u can get the gallon can for 25 bucks at autozone or advanced auto after 45 minutes pull out the carb and blow off wih air chuck from an air compressor blow out all the littlle holes they are inside and out reinstall float and needle valve reinstall bowl turn air fuel mixture screw all the way in till snug do not over tighten or youll damage it turn back out counter clock wise 2 turns reinstall carb thank me
May 14, 2012 | Briggs & Stratton Briggs Stratton Intek V...
21 hp briggs on husky mower runs fine but intermittently acts like it is flooding ie.it starts losing power and i can see small amount of black smoke.if i pull the choke on easy it will stall.sometimes...
I had the same problem with mine. I talked to briggs help line and that was useless and also talked to 6 other repair shops. Seems to be a dirty little secret they are keeping about the defective carbs they use. Only way to fix it is to get the redesigned carb they have out now. They changed the fuel bowl and solenoid assembly. Carb kits did me no good.
Jul 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My 6.5 HP B+G lawn mower has gradually required more priming to start and now will not continue to run without constant priming. I have sisassembled the housing and found that the two screws that hold the...
remove the sediment bowl on the bottom of the carb and see how much dirt/contaminent is in the bowl,then lift the float (the metal or plastic round donut shaped object in the bowl) and see if gas runs out,if not then the carb is plugged and engine wont get gas to operate,then you need to try carb cleaner or a complete carb rebuild
Apr 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 20hp twin cylinder runs only with full choke
Had one on my saw mill had this problem as well Try pulling bowl off bottom of carby as the float can get **** with old fuel especially ethanol fuels as they attract water bowl is normally held on with one center screw on bottom of carby. Note always turn fuel off and let engine run out of fuel as this stops goop from building up in carby
Sep 04, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine starving for fuel, fuel filter very low, almost empty
your fuel pump is diaghram actuated by pulses from crankcase pressure, if you look there is a small tube that runs from pump to valve cover, pull fuel line off carb and have some one crank it over to see if it's pumping. could be pump or blockage between tank and pump, if fuel flow seems good to carb, i would pull bowl off and check for dirt and also make sure anti run on valve, the thinghy that holds the bowl on to carb is opening properly, it should open and close when you turn key from off to run, beyond that it could be you have some water in your gas.
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Fuel in tank going into engine and mixing with oil
The float needle and seat are leaking and not shutting off the fuel when carb bowl if full. It then flows down the intake into the cylinder, past the rings and into the crankcase. Have the needle and pressed-in brass seat replaced. Could save yourself some money if you removed the carb yourself and took it in.
Jun 12, 2009 | Parks Optical 13.5hp Briggs And Stratton...
My briggs & stratton will not start
If the engine fires on starting fluid, then you are missing fuel, so you need to start with the source, is fuel getting to the carb? if not why not. Check fuel lines, shut off valves and filters.
If it is, is the carb float allowing the bowl to fill?
If there is fuel in th float bowl, then you need to look at mixture and idle settings.
hope this is of some help.
Ed
Apr 19, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
1,844 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
