Question about Dell 1700n Laser Printer
Who can fix my printer from paper jamming? It is a Dell Laser Printer 1700 and keeps jamin the paper. Who do I call? Have tried almost everything.We live in a remote Mountain area Colorado.
If you mean that the print cycle starts, but the "Paper Jam" lights up at the point where the paper starts to enter the drum, here's what I found worked.
The rollers that feed the paper come down onto the clean sheets on a plastic, spring-loaded arm Those rollers sometimes get too slick after a lot of use and they won't push the paper up and into the drum -- they slip like worn tires.
Solution: slip the rubber "tires"off the plastic roller "wheels" and reverse them, inside-out. Put them back on the wheels and the new rubber surface will probably push the paper just fine.
To do this you have to turn the machine upside down and remove the paper tray. I would unplug the unit and remove the drum as well before trying this.
Good luck.
Posted on Jul 08, 2009
Our printer is having paper jams in the back we have cleaned the printer and took it apart to see what was wrong and it still keeps happening is there anywhere we can take it to
You may have some luck trying some of the tricks found here. I have a 1700 myself, but don't use it much...works great when I do thou!
Aug 13, 2009 | Dell 1700 Laser Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
Dell 1700 printer paper jams
if the paper is jamming at the back of the unit, and looks like an accordian after removal, it's more than likely only the paper sensor on the fuser. i dont recall the part number, but it can be had from online suppliers for under $40.
Nov 10, 2008 | Dell 1700n Laser Printer
Dell 1700
I've experienced this in the past and found a paper jam in the back feed roller and had to take the unit apart to retreave document. Try doing this (only if no longer under warranty) there are a few screws in the front and it should be able to come off easily.
Nov 10, 2008 | Dell 1710n Laser Printer
Paper cannot pass the Fuser/pressure rollers
We have many of the 1700N printers and have found that the 2 paper pickup tires must be in good condition to avoid frequent jams. I would highly suggest replacing the 2 paper pickup tires if this printer has a lot of copies on it.You can slip the tires off of the plastic roller and see if they are shiny. If so, replace them.
Aug 12, 2008 | Dell 1710n Laser Printer
Dell Laser printer 1700
pickup rollers bad, you can try to clean them with rubber cleaner but it's best to have the rollers replaced.
Jan 22, 2008 | Laser 22 ppm Mono Printer
Dell 1700 Transfer Roller
These series printers have a typical problem of the paper pickup rollers wearing out resulting in jams, crooked feeds and partial feeds. a quick fix:
take the paper tray out, turn the printer on edge and locate those two rubber roller bands on the pickup arm. Peel them off, flip them inside-out and return them to the rollers. This restores thier sticky rubber side so the papper feeds properly.
Now if you are a heavy printer, you can order some of these from dell for the next time. Washing these in handsaop and water works sometimes too. never use alcohol.
Jan 06, 2008 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Logo
841 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
