Question about Oreck XLS700A Upright Vacuum
Stopped working suddenly. wont come back on.
My vacuum stopped working suddenly
  • 281 Answers
Try another otlet.if you have it plugged into a gfi outlet the little circit beraker on the outlet might have trippid if so push in on the red buttom till you hear it ckick.thatd resetting the gfi outlet.those kind of outlets can be found in thr kitchen,bathroom and outside.
Posted on May 03, 2009
Eureka Mighty Mite 3670 Bagged Canister Vacuum just stopped working
Should be under warranty. Take it to a warranty center for repair
Jan 05, 2014 | Eureka Mighty Mite 3670 Bagged Canister...
While vacuuming with my hoover mach 5 it all the sudden shut down
Hi, If it is warm to the touch, and it just shut down all of a sudden, I would say that the motor has an internal over load switch that is normally closed, and opened to stop from burning this vac out. It is a built-in safety. I would look at the roller for anything that may have hung up, but steady use for an hour just over heated the motor. Let it cool way down. Try and start it. Also, check the plug to see if you may have lost power there also. Let me know please so I can be of any help you may need.
Sincerely,
Shastalaker7
Nov 08, 2009 | Vacuums
Vacuum stopped working and wont run
Check the cord to be sure its not broken anywhere.
Check the roller, it may be clogged
Oct 30, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The hand-held wand wont slide back into the tube. It wont go down far enough to click in and become the handle again. It was working fine but all of the sudden won't fit back in.
sounds like the tube has something inside of it that is obstructing the path. veriffy the the "female" end of the tube isnt obstructed, and also, make sure that nothing is bent ( which can happen easily). use a flashlight to shine down into the tubes and check everything out. you shouldnt need to use a lot of pressure when trying to make the tubes fit. if it doesnt fit, dont force it, basically.....try turning the tube too, and that should work.
Sep 24, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Bissell Vacuum brush stopped rolling
The belt may be broken. Consult the user manual or locate on the sole plate or front hood when getting to the sole plate. Usually it involves a few cross head screws on the base of the vacuum cleaner where the roller beater bar is. Remove that and check the belt. If its broken, carefully replace it with a new one and see if that works once everything else has been put back.
Mar 27, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Stopped working
It cooled down and worked 20 minutes later
Aug 28, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Motor and Lights stopped suddenly after vacuuming the stairs.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19809&thid=745467
Motor and Lights stopped suddenly after vacuuming...
Posted by Brigham81 on Jul 05, 2008
I was vacuuming the stairs, and all of a sudden the light went out and the motor stopped. Is it possible to overheat it, or blow a fuse? Thanks, Brigham
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL2200 Bagged Upright Vacuum. It sounds to me that when the lights go out and it stops working that the motor is bad that you would have to replace the motor. It is still cheaper to replace the motor than to purchase a new vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 05, 2008 | Oreck XL2200 Bagged Upright Vacuum
Dirt Devil Purpose for Pets suddenly stopped vacuuming, totally cutting off. Checked plug and outlet for problems which were negative.
I had this same problem. All of a sudden it shuts off while vacuuming and then i'd have to wait a while before it would turn back on. Finally it stopped working period. Before going out to buy a new vacuum, I decided to take the thing apart and clean it up really good. That included running a clothes hanger through the tubes to get all the stuck hair out, removing the roller and getting all the hair untangled from it, and rinsing out the air filters (both the sponge and the plastic piece with the paper like filter) with hot water. Then you let the filters dry for a day or two. The plastic/paper filter takes longer to dry so I used a hair dryer. The vacuum itself is not hard to take apart. I think there are only 11 total screws you need to take out. After the filters dried I put them back in the newly cleaned vacuum and it worked like new. I think the main problem was the condition of the filters. They can get pretty filthy over time, which will limit the air flow to the motor. With less air the motor is more likely to overheat and shut off. So keep your filters clean and you shouldn't have any proplems.
Apr 03, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Oreck XLS700A Upright Vacuum Logo
375 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
