Hello, I'm not a salesman, I really do try my best to help people. I would suggest replacing the Oven, not just the part on a machine of that age. I hope that was a help?
Providing the existing switch outlet iscontrolled by a 30amp circuit fuse or trip, then there is no problem connecting the 2 appliances to the same switch.
If on the other hand, it is controlled by a 13 amp breaker, then you cannot connect both appliances to this, you would have to use 2 seperate sockets.
Hope this clarifys your question.
How to explain this? your new drop in unit will require a 220v circuit capable of a specified amount of amps. Typically 40, 50 or 60. Should be noted in the manual and on the unit itself. If your original oven and cooktop were electric, then each one was probably hooked up to a 220v circuit. The problem is figuring out how many amps were supplied for each. The simplest way is the go to the panel and find the breaker for the old oven and cooktop and read the numbers (or amps) on the on/off switch. If either breaker has a number the same or greater then the drop in unit says it requires, then your all set. If the drop in unit says it requires 52amps and one of the breakers says 60 on it, your fine. If the drop in unit says it requires 44amps and the breakers are 30 or 40, then you got a problem. Usually a breaker is installed that is the maximum amps allowed for the size (thickness) of the wire connected to it. You CANNOT connected a 50a breaker to wire only rated for 40a. Note the size difference of wire connected to a 20a breaker with wire connected to 40a breaker. If the drop in unit requires more amps then the original units used, then a larger wire will need to be ran from the panel to the drop in unit (Not cheap). Now if the original oven used a 30a and the original cooktop used a 30a, then its possible ( 80% of electricians wouldn't do it because of liability problems) to use both wires together to create 60amps, but both wires (actually a total of 6 wires, 2-120v wires and 1 ground wire from each outlet) would need to be in the same outlet box for the drop in unit connection.. I could (and probably should) try to explain more, but I'de probably just confuse you more. GOOD LUCK!
