Question about JBL On Stage Micro Portable Speaker Dock for Apple iPod - Black
When plugged in, the ipod batteries go low immediately.
I can only play about 4 songs and then the battteries of the ipod show that they need recharging... Even if the batteries are full when put into the jbl on stage micro. This only happens when sing the jbl on stage. Would anyone know how to solve this?? Is the problem maybe the ipod??
  • PsychAmanda Apr 26, 2009
    I have an iPod Mini and this is the only problem I have had with the Onstage speakers.
  • twotalentguy May 04, 2009
    I have noticed this happen several times - usually at the most inconvenient times. I have an iPod classic, and even as I'm typing this, the JBL On Stage Micro is plugged in (to a good outlet) and the iPod is cradled in it... And the iPod batteries have been getting progressively lower and are about to die.
  • 3 Answers
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
Posted on Sep 26, 2009
My ipod model a 1285 keeps turning itself off why
iPod keeps turning off Plug your iPod in overnight to make sure it has charge. If after a full night of charging it has a low battery, there is probably something wrong with your charger cable. Replace the charger cable, especially if yours is old or has ever gotten significantly dirty. Reset your iPod. This basic reset does not remove any content from your iPod. Apple suggests this soft reset as the first fix for any software problems or if the screen freezes. Eject your iPod from your computer first. For an iPod with a click wheel, toggle the hold switch on and off several times, then hold down "Menu" and the center button at the same time until the Apple logo shows up on the screen. For touchscreen iPods, hold down the "Sleep" button at the top right until the Apple logo shows on the screen. Perform a factory restore on your iPod if the previous steps do not fix the problem. Plug it into your computer and open iTunes. Click on your iPod, then click "Restore." This wipes all content from your iPod and re-installs the operating system.
b> iPod Keeps Cutting Off b> Your iPod may cut off during a song or video, or during an application. Different causes lead to different types of cutting off just the sound may disappear, or you may suddenly experience cutting to a different screen. For example, if your iPod cuts off during a song, you may have merely hit the "Pause" button. With a blank white screen, you're encountering a software problem. Whatever the reason, follow some simple troubleshooting steps before contacting Apple's customer service.
Headphones Check that your headphones are connected correctly if the sound cuts out suddenly. If the 3.5-mm headphone jack comes out even a little bit, it can make the sound cut out in one or both headphones. Check for debris in the headphone jack itself, which can prevent a solid contact between the headphones and the iPod. b> Other Sound Issues b> Make sure the volume is up high enough. Also, especially if the iPod is in your pocket, make sure you haven't bumped the pause or sleep button. To ensure that audio plays constantly, engage the lock on your iPod. The music will always stop when you pull out the headphones, and once the headphones are back in, you have to push "Play" again. Cutting to White Screen b> A sudden white screen may appear when a generic software malfunction occurs, one in which t you don't get an error message. You must reset the iPod by turning it off, then on again. If this happens several times and you are using the same application each time, that app may be faulty. Try re-installing or re downloading the app. b> Cutting to Black Screen b> An iPod that cuts out to a black screen and won't turn back on is usually out of power. Usually you'll see a low battery warning, but if you're not looking at your iPod when the warning flashes, you might miss it. Once you connect your iPod to a functional power outlet, you can turn it on immediately, but it's best to wait a few minutes when the battery is very low. This gives the iPod a chance to regain power so it can function normally when you plug it in. Hope it helps.
Jan 22, 2013 | Apple iPod Audio Players & Recorders
I can not play
Use itunes. It's made to work perfectly for the ipods. You can update the firmware and software using that. You can do a lot with itunes.
Change tags, info, and make playlists, update the whole ipod, reformat it so it's like new.
Feb 08, 2009 | Apple iPod nano
My ipod 2gb need help!!!!!!!!!!!
Please restore it and check
Oct 11, 2008 | Apple iPod nano
IPOD mini won't play purchased music unless 100% charged
I've called Apple support on this before. They told me to make sure that the Ipod is set for Manually manage music in the Ipod settings of ITunes. You should restore all software in your IPod to factory settings before doing this.
Jul 14, 2008 | Apple iPod mini M9160LL/A MP3 Player
Ipod won't show my songs, any ideas?
for this... first plug the ipod to computer then restart the system.... i had the same problem, it works.
Jun 21, 2008 | Apple iPod nano 3rd Generation
IPod mini battery dies when nearly fully charged, often while skipping songs.
iPod batteries are cheap on ebay...like $5...and come with installation instructions. Try installing a new battery and see what happens...?
Feb 11, 2008 | Apple iPod mini 2nd generation MP3 Player
Ipod not playing songs
restore to factory setting using the software. that could help.
Nov 24, 2007 | Apple iPod nano
Song on a shuffle pattern
I ran into the same problem about a month back. I tried everything to fix it. I finally brought it into the Apple Store and they said something inside the iPod was fried and they didnt have the tools to open it up and fix it righ there. They guy just gave me a new one for $32 (a battery recycle fee) I didnt have a warrenty but it was less then a year old. MY suggestion is to bring it in and see if they can fix it but more then likely your going to need a reapair.
Dec 26, 2006 | Apple iPod MA446LL/A MP3 Player
JBL On Stage Micro Portable Speaker Dock for Apple iPod - Black Logo
331 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
