Question about Dual XDMR7710 CD Player
Wiring for stereo in 94 ford explorer
I'm trying to wire in an aftermarket deck on a 1994 ford explorer. I bought a wiring harness for it. It came with 2 similar pieces in the package. one for power options and such and the other for all of the speakers. I have the power harness all wired in but I cannot for the life of me figure out how to wire in the other harness. The stock deck has an square shaped plug and I'm pretty sure that's where the speaker harness should be. the harness I bought will not fit into that plug. Nor can I find a base. I dont want to just cut the plug off and find out that I shouldnt have.
Sounds like you have the Premium Sound system. The main power plug is long and probably black, the other plug is square with a grey round cord coming out correct?
You can either take your power harness back and get the correct one ( a little more expensive) or run ALL 4 sets of speaker wires back to the right rear quarter panel. That is were the OEM amp is mounted and taking that panel out requires you to remove the top and bottom tailgate trims, a dozen screws, the seat belt D-ring and 4-5 plastic push clips that will probably snap off...:( Also, this will not make the OEM subwoofer work.
From 20 years experiance in this biz, save the time, spend the extra 30$ or so and just buy the correct connector. Check MetraOnline.com and search there.
Scott
Posted on May 11, 2009
Need help hooking up my radio
Posted on Dec 05, 2009
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
How do I wire after market stereo to 94 ford probe
check the radio stores as you may be able to get a radio harness to connect the aftermarket radio to the factory wiring harness so you won`t have to cut and splice, its just a plug and go.
Oct 13, 2014 | 1994 Ford Probe
I have a 1985 ford ltd crown vic I just bought a aftermarket radio but the wiring isn't the same its still has the factory radio and wiring kit how do I change them in order to use my new cd player
You can go to best buy or a stereo shop they have wiring harnesses and fit kits for aftermarket CD player the wiring harness plugs into the stock wiring harness the u have to match the wires to the cd play
Mar 28, 2014 | Cars & Trucks
Aftermarket stereo turns on but can't hear anything 1997 explorer
Did the truck have the premium sound system? If so, you will need to connect the blue remote wire to the blue remote wire on the harness. You may also need a special harness to bypass the factory amplifier.
Jan 10, 2014 | Car Audio & Video
I bought a wiring harness for my honda to hook up my stereo deck and but it wont turn on, are the color codes different or just match the color to color??
If you mean you bought a wiring harness adapter for your car so you could hook up an aftermarket deck - yes it's just color for color then.
Feb 03, 2011 | Clarion Car Audio & Video
Have sony cd player and wires in my 94 ford tarus dnt match up 2 my sony cd player
GO to your local Walmart store and in the Car stereo dept. You will be looking for a factory to aftermarket wiring adapter FD02B made by Scosche. c7d9e5d.jpg
This will plug into the factory plugs and then have lead wires of the same or similar colors and a wiring schematic to use.
It can also be found online at www.scosche.com/products/productID/226
If you are missing the factory wiring plugs you can also order these online, Walmart doesn't usually carry the factory wiring harness.
Great company and line of products.
Thanks for your question, Dorrian
Aug 08, 2010 | 1994 Ford Taurus
Putting cd player in 94 explorer?? HELP PLEASE?!?!?!?
Yes, that would be fine, make sure you solder the wires and tape well or use shrink tube on the connections.
Mar 13, 2010 | 1994 Ford Explorer Limited
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
Jan 05, 2009 | 1994 Chevrolet Suburban
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
Dual XDMR7710 CD Player Logo
1,052 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
