Question about Maytag MSD2732GR Side by Side Refrigerator
Door dhute not opening to let ice fall
I have a Maytag MSD2432GR. I ordered a new door-chute and installed it. The ice falls but the chute won't let the ice fall down. Can someone tell me what to do.
  • taurusswede May 09, 2009
    That is exactly what was wrong. Thank you! I kept putting the metal barrel in wrong. When it is in correctly it holds the door chute open.
On the right hand side of the door chute there is a little metal barrel that needs to be attached to the end of the arm that holds the ice door. this is attached to the spring that opens and closes the door chute.
Posted on May 06, 2009
Lg lmx25984 ice chute flap will not open automatically
On Mine, the solenoid connection fell off that allows the ice to dispense, Thank you so much!
Aug 04, 2012 | LG LMX25984ST 24.7 Cu.Ft. French 4-Door...
Our new 48" Viking side by side does not feed ice cubes adequately. If you need several glasses of cubes it stops feeding and when one opens the freezer door they are piled up and fall all over the floor....
I experienced the same problem several times with our VCSB483DSS also.
What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.
I think the the problems are:
1 - over application of foam insulation in the chute pathway in the door.
2 - possible bad timing on the flap opening causing the falling ice to get stuck.
My solution for the past 6 years:
1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.
2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.
Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
Oct 09, 2010 | Viking 42 in Built In Professional...
Little door that lets ice fall into glass won't
need to check door chute hinge it could be broken
Nov 05, 2009 | Kenmore Refrigerators
Ice is forming around the auger under the ice bin. constantly have water dripping from ice cube shoot
the door that the ice comes down to fill glass is not closing; the ice chute door just above the lever to fiil glass with ice it is either jamed with ice or is broken and needs a new repair kit.you can inspect by opening door and look at approx. 3 inch door that ice falls threw to see if closed.warm air causes ice to form.
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
ICE DOOR WILL NOT LET ICE FALL DOWN CHUTE,
the ice door has a solenoid that opens and closes the ice door. since you were able to replae the door i assume you can take it apart pull it back apart and the crank the door attaches too is connected on 1 side to an electrical soleiod test if the plunger moves up and down freely. also look for heat deformation around the plastic as well. if it turns out the solenoid is bad i would also recomend replacing the the fountain boards as well. I dont think you can put to much tension on the spring..
Jan 30, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ice chute door on maytag refrigerator
the door is opened by a solenoid. it is bad or it is not getting voltage due to bad control or wiring
Apr 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
The ice flap in the door does not open when ice falls down the chute
The door is opened by a electrical solonoid, not by the ice itself. This solonid gets corroded due to moisture, To axcess the solonoid remove water tray remove three torx screws removing trim panel, remove 3 more torx screw holding dispenser module to freezer door two on either sides and one by paddle. Maytag has a kit called a fountain door kit that has everything to rebuild the ice door system,
Jan 10, 2008 | Maytag MSD2454G Side by Side Refrigerator
Ice dispenser
make sure that the flap is sitting in properly. if it is and problem still happens then i'd say that its a design fault
Nov 10, 2007 | Maytag MSD2756GES Side by Side...
Maytag MSD2732GR Side by Side Refrigerator Logo
432 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
