I am using a washing machine, Estate by Whirlpool Corporation, and the first load, following any period of time that the washer has not been used (1-2 days), always smells like rotten eggs. The washer is approx. 4 years old and has been used in this location almost two years. It has always done this in this location. I don't know if it smelled in the previous location. What could the problem be and how could this be fixed?
A solution from the internet: Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell.
Another: I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com
Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine.
I have a top loader Maytag and the cloths never smell clean even if i retrieve them as soon as the wash is complete. You use to open the top and smell the smell of Tide and fabric softener and now it just smells musty and dirty for every wash even with hot water and bleach.
The drain pump seems to run for a very long time and a slight smell in the laundry room is present...
(More)
The drain pump seems to run for a very long time and a slight smell in the laundry room is present (burnt motor type of smell)Each wash cycle takes a long time to finish too.
