Question about Sharp AR-M455N Copier
Misfeeds My Sharp AR-M455N copier is telling me I have a misfeed when I am certain that I do not. The misfeed paper has been removed but the misfeed notice on the screen won't go away so I can't print or copy anything else. Is there some way to override the misfeed notice?
  • Anonymous Mar 12, 2014
    A misfeed occurred while I was running copies. The paper ripped, but I have removed every piece of that torn sheet, but the error message on the copier still says 'paper misfeed' and shows an arrow pointing to the output center tray also known as the Paper Pass Unit. I have removed that drawer, check for paper, and even use suction just in case there was something that I couldn't see while using a very bright flashlight.
  • 163 Answers
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Posted on Sep 16, 2007
  • 62 Answers
Unplug the machine from the wall . If the problem still there open all the trays look inside sometime the paper feed in a little and cause this problem or check the finisher.
Posted on Oct 11, 2007
SOURCE:
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Black Toner Cartridge For AR-M355N,...
Call for service h5-01
5 consecutive misfeeds have occurred. clean feed rollers, tyres etc and switch machine off and on to reset. fingers crossed thats all it is otherwise your looking at sensor troubles.
Dec 12, 2013 | Sharp AR-M237 Digital Copier
Tray
sir my machine sharp AR-m420u take code H3-01 whats meen this code......?
Dec 03, 2013 | Sharp AR-M455N Copier
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Nov 01, 2013 | Sharp AR-M205 Copier
Sharp AR-205 misfeeds at transport area from both paper trays and bypass tray both. Tested using different paper in all trays and still won't feed in at the transport area. The paper just pleats up...
it means the drum is not moving check it, insert it properly. or therre is a broken gear somewhere or the motor that makes the drum to rotate is not working properly. The registration sensor not working or not postioned properly.
Aug 01, 2011 | Sharp Office Equipment & Supplies
Code H5-01 on Sharp AR-M450N. Cleared jam. How do we reset? Thanks
H5-01 is repeated jamming in the fuser unit, please check you have removed all paper from the heat section. press P/# * C * then 14 and copy start and follow the instructions on screen to reset.
Oct 14, 2010 | Sharp AR-M455N Copier
Error code U2-22 Model #AR-M455N what's wrong with the copier?
MFPC SDRAM memory check sum error. Remove the back print control board (shiny metal + slides out like a draw) remove and refit memory cards.
Sep 27, 2010 | Sharp AR-M455N Copier
Copier Sharp AR-M237 a Misfeed Occurred message
First try a different tray to see if it works, if it does than the paper tray you are using may have dirty feed tires or look for something obstructing it.
Mar 24, 2010 | Kyocera CopyStar CS-3060 Black and White...
Streaking problem on Sharp Copier SF-7321
Clean the optical mirrors on the scanning side and also remove the drum and clean a mirror beneath. Check also the drum condition and replace if necessary.
Dec 21, 2009 | Sharp AR-5320 Black and White Copier
Misfeeds
We lease the copier and have a maintenance contract. We call for a technician to come out and fix the problem. I was trying to find out if there was something preventive that we could do to avoid the misfeeds. For instance, maybe a particular type of paper (brand) is recommended. We use different brands but all are 20lb bond (some recycled, some not). We attempt to keep the paper from absorbing humidity, keeping it in its wrapper until use. Often I think it is that the sensors in the copier get "dusty" and then don't function properly. The user cannot get to these sensors -- that takes a technician.
Mar 03, 2009 | Kyocera Mita Office Equipment & Supplies
Sharp AR-M455N Copier Logo
757 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
