Question about Cameras
How do i take my camera apart?
My m1063 screen is scratched on the in side how do i properly take it apart
  • 98 Answers
I see it's an Kodak camera. We have new LCD's for this type Contact Rotronica in the Netherlands to provide an LCD
Regards,
Rob
Posted on Apr 16, 2009
Tip
How to replace LCD Screen on a Nikon L18 Coolpix camera
Here is a Quick tutorial on replacing the LCD screen on a Nikon L18 Coolpix camera. You will need a few small tools and a replacement screen, of course, for this fix.
#0 Philips head screwdriver
1.4 mm Standard screwdriver
Plastic knife
1. Start by taking the batteries out of the camera and closing the battery compartment.
2. Remove 6 Philips screws, 3 from the bottom, 1 from each side, and 1 under the AV out flap.
3. Open the battery compartment and gently pry the AV out side of the camera apart. It should snap apart along the seam in the middle. Use your standard screwdriver to pry the back cover off by working it along the seam. If you are worried about scratching the finish you could use the plastic knife once you have it started.
4. Remove the back cover exposing the screen. The screen sits in a metal chassis that holds it in place. Lift the screen from the AV out side of the camera. Under the screen is a ribbon that connects it to the camera. Disconnect the ribbon and remove the old screen.
5. Install the new screen by connecting the ribbon and seating it in its chassis. You can test the camera by installing the batteries and pushing power to see if it functions.
6. Place back cover carefully back over the screen before pressing it in place.
7. Screw it back together and start taking pictures again.
Good Luck and thanks for using Fixya
Kaufman605
on Dec 16, 2010 | Cameras
The screen cracked and scratched. . . is it possible to replace it?
Yes, it is possible to replace lcd screen in this camera, local camera repair shop will help you to get it replaced because camera will take apart and that needs expertise to work done in safe and correct manners.
Aug 17, 2010 | Sanyo VPCE890 Digital Camera
Hi my kodak m1063 will not zoom in
http://www.kodak.com/global/en/service/products/ekn035308.jhtml?pq-path=13050
I input 'won't zoom in' but didn't get a specific result that seemed to be helpful and answers your question.
What about your camera will not zoom?
Do you try to hit the zoom switch or button and the image does not get bigger on the screen?
Jul 29, 2010 | Kodak EASYSHARE M1063 Digital Camera
My Kodak M1063 digital camera will not turn on no power at all
Kodak EASYSHARE M1063 Digital Camera My Kodak M1063 digital camera will... Answer my camera will not turn on no power at all.
Feb 13, 2010 | Kodak EASYSHARE M1063 Digital Camera
M1063 kodak digital camera
If you've recently dropped the camera you may have lens damage that's preventing the camera from operating properly. If it hasn't been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. A "Very Helpful" would be greatly appreciated.
Nov 23, 2009 | Kodak EASYSHARE M1063 Digital Camera
Pink colored pictures from my digital camera
For this problem try doing the ff:
  • transfer the photos to the computer
  • set the camera in auto mode
  • take a picture
  • if the picture is still pink and blurry even after transferring to your computer
  • call the tech number 18002356325
Thanks
Byron
Sep 22, 2009 | Kodak EASYSHARE M1063 Digital Camera
Dust under screen.
The camera has to be taken apart. First - the front cover, then the back cover. You will need some compressed air.
Tom
Sep 20, 2009 | Kodak EASYSHARE M1063 Digital Camera
My Kodak Easyshare M1063 won't turn on
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem and this fixed it, it seems to be a common problem.
Aug 13, 2009 | Kodak EASYSHARE M1063 Digital Camera
Red hand icon when on my pix on ny camera
It means basically that there was not enough light to properly process the picture OR the shutter snapped before it was fully focused.
Jul 31, 2009 | Kodak EASYSHARE M1063 Digital Camera
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
