Question about Motorola Mobility RAZR V3
Charge/nonfunction lost the batt. level icon , phone worked for a day, then shut off and will not accept a charge.
    Brigadier General:
  • 7,752 Answers
You have to get the firmware reflash on the phone, this should correct the issue.
Posted on Feb 17, 2008
SOURCE:
My phone was working fine, I put it to charge the next day I realized was not charged
probably your fone batt is extrem low. you need to find 5volt dc source to "recharge" your batt to the minimum state so you can recharge it again using your daily charger.
Sep 23, 2015 | ZTE Boost Max Black Boost Mobile
MY PHONE WONT CHARGE
The power cells lost the ability to accept a charge. Noting you can do will revive the energy absorption. Replace the power cells and charge for 24 hours. Use the phone until the charge has completely drawn down and the phone shuts off. Re-charge over night to set the battery memory for a full charge. Your done!
Feb 26, 2014 | ZTE Warp
When car sits for more than 1 day battery is dead
either your batt went bad or car not charging batt. beyond that i look for trunk, dome or under hood lights that dont shut off slowly drainng batt.
Jan 29, 2011 | Mercury Cougar Cars & Trucks
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
Razor will not charge
my own razor does this also. the problem is the charging port on the phone. try using an electronics cleaner inside the port but do not oervsaturate. Otherwise if the phone is warrantied or you have insurance take your phone in and get it changed. I had a spare phone that i use to charge my battery. hope this helps.
Sep 11, 2008 | Motorola Mobility RAZR V3
1997 Jeep grand Cheeroke
My Answer:
Being an expert in this Electronics field this should be fairly easy.
It appears your charging system is functioning OK as you did the QUICKIE alternator/regulator test and that part appears to be fine.
Next - Never ASSUME you have a good, or NEW battery. I've seen brand new batts fail a few months after purchase for no known reason at all. Water level should be topped off esp during Hotter weather as water level will drop as the batt ages.
AND - when in doubt - Always do a hydrometer test on each cell, and make sure all cells read equally at approx 1.285 to 1.290 - indicating a fully charged batt.
When doing a LOAD TEST with an external 100 Amp Load Tester make sure you disconnect the POS terminal cable (or better yet both batt cables) on the batt before doing a good Load Test on a fully charged batt.
Batt voltage on a good fully charged batt should never drop much below 11.4 to 11.7 volts doing a 10 second load test using a Load Tester similar to say one bought at Harbor Freight Tools for like $15 when they are on sale.
If the top of the batt is wet (for whatever reason such as dew-point or leaky batt acid) this will cause the batt to self-discharge right across the top of the batt. Just like putting a small light-bulb across the batt posts and causing a drain. It happens more times than you care to know. When I worked at SEARS I seen it day in and day out......trust me I know!
Next - you'll want to check for a couple things at night, or else daylight will work as well - if you have good eyesight. You want to check and make sure your "backup lights" aren't ON when the Headlights Switch is turned OFF and the Ignition Switch is OFF as well. Sometimes a SHORTED Transmission Backup Light Switch will cause a battery drain with everything shut off. Sometimes!
Also - If you have any Interior Lights left on when the SUV doors are all closed that will surely drain the battery down.
A radio/stereo left ON will do the same as well.
A shorted tail-light (or any marker light) will also cause a battery to drain over time.
Jeeps that have a under the hood light Mercury Tilt Switch for the Engine compartment sometimes can have this switch mounting come loose and when you shut the hood the light will actually stay lit thus draining the batt down as well. Make sure you check it at NIGHT during darkness as it will show up better.
If all this proves NOT to be the cause then you will have to do an actual DVM inline amp meter test to see just how much current leakage (shorting) you have. A fuse block isolation test will next have to be done to isolate from which circuit leg the short (or current drain) is coming from.
Once that circuit is isolated then it's just a matter of finding the shorted device or shorted wire(s).
If you just added anything new electrical wise to the Jeep recently- then that is a good starting point - for if the problem wasn't there before that time, and now it is - then there is your culprit!
If you are using an external battery charging PV (Photo-voltaic) panel, and it's bad for any reason - then it will drain your battery down as well, esp if the blocking or back diode goes bad.
Also - If you have a dual battery system with a BATTERY ISOLATOR installed you might want to double check all your wiring there as well - as I've seen them go bad and cause many a battery problem!
It's gotta be something I just went over here - as I covered everything......
Let me know what it was OK?
Thx,
Frank
Jul 12, 2008 | 2003 Jeep Grand Cherokee
Keeps shutting down.
The solution is found! There's no need to format your HDD
So.
- Unplug the battery;
- Press and hold the reset button for 20-25 sec;
- Put the battery back to it's place;
- Charge your device (when you plug the cable in, it turns on (note that a blinking lightning icon appears on the charging indicator), then it turns off with it's "shutting down" message, dont pay attention on this, just let it charge for about 10-15 minutes (note that the CHG bulb won't be lit));
- Turn on your device. The CHG bulb is lit, Archos doesn't shut down
- Enjoy
Jan 08, 2008 | Archos 504 500870 Digital Media Player
Phone shuts off during operation.
hi
im sure you have a batt prob...
have your batt replaced and im sure your prob is solved...
Oct 12, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
