Question about Polar F11 Heart Rate Monitor
Polar F11F Error 16
I have recently changed the battery in my Polar F11F and all was working fine for about two weeks. The screen went scrambled and was unreadable and then error 16 was then displayed. You can sometimes see error 16 displayed but sometimes you can't.
I have looked in the manual and nothing!
Any help/advice is warmly welcome.
Cheers
  • Anonymous May 23, 2009
    My screen scrambled as well...I got the battery replaced and now it says error 16 on it as well...HELP!!!! I NEED MY WATCH!!!
You need to hold down all 4 or 5 buttons at once. This will reset your watch and bring up the message "welcome to polar fitness world". Press ok button 1x to start your setup process.
Posted on Mar 09, 2010
I pressed al the 5 buttons at once, was a little bit tricky, but pressed the center button on the right on a table and used my fingers for the other 4 buttons.
Screen went completely black, al the symbols were shown.
After a while, I had to re-enter the settings.
It's working now :D Only problem is that the hr-sensor isn't working..probably also a dead battery.
Posted on Mar 25, 2010
Hi, my polar ft80 (black screen, white numbers), stops working quite often. The screen turns black and when it comes back, i have to go through the settings screens again. It happens about once or twice...
probably there's a problem with the connection of the battery of your watch, that's why it turns off, second it might have a different size of battery that have been installed. or the battery is not properly installed. these are all the possible cause of your watch. i hope i had been helped you.
Jul 22, 2011 | Polar FT80 Heart Rate Monitor Watch...
Got "memory failed" measage on
push red button for 15-25 sec
Feb 17, 2011 | Polar S-725 Wrist Watch
Battery replacement polar cadence sensor CS 200
Polar sucks, I'm going to Cateye
Sep 06, 2009 | Polar CS200
The screen scrambled and went dead and does now not work
That is my thought aswell. Change out the screen. It isn't hard at all. They are less then 20 bucks on Ebay. I wroke a quick guide you can take a look at to help you out.
http://www.howtofixmyphone.com/how-to-replace-a-cracked-or-broken-nokia-2610-lcd-screen/179/
Hope this helps you out.
Jun 24, 2009 | Nokia 2610 Cellular Phone
Hi i have change the battery in a polar f6 but?
Make sure you don't have the battery in upside down. The large outside case of a button cell is the +positive side.
Feb 20, 2009 | Polar F6 Wrist Watch
Polar F11 ''Scrambled/Smudged'' Display
You have to replace the battery with the new one. In most cases underpowered battery causes faded or even disappearing digits on LCD unless your watch has been damaged by water. Find your nearest watch repair shop or do it yourself. Do not forget to rate, please.
Jan 21, 2009 | Polar F11 Heart Rate Monitor
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
MDA phone screen is scrambled with Lines
Marc1234: sounds like the backlight is out......possibly a software malfunction.....try goign to www.t-mobile.com/wmuprade to reinstall the software....if that doesnt work, contact htc or your service provider....you will need a replacement. if youre out of warrenty, it will be a lost cause....
Guest,: your USB port is broken, if you dont fix it yourself, you will need another phone.
Oct 17, 2007 | T-Mobile MDA
Connection Problem between the LCD screen and PC board
Sometimes you can solve this sort of problem by sticking a couple of small pieces of tape on the front side of the lcd screen in places where they wont be visible on the outside - they will push the screen back onto its connections - there is quite possibly a small piece or seal that is now missing that would have done this job before. If you want to conatct polar directly for help go to this link - you can get a user manual and all the contact details for service etc. http://www.polarusa.com/Products/fseries/f6.asp?cat=consumer My advice would be to send it to them to get it fixed - replacing a battery on its own is rarely all that needs to be done to a watch when the battery runs out - it is a convenient service interval as seals need replacing, parts need checking or lubricating or cleaning etc. Hope this helps :)
Apr 15, 2007 | Polar F6 Wrist Watch
Polar F11 Heart Rate Monitor Logo
2,091 people viewed this question
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
