Broken Latch My latch that open my laptop is broken. I want to replace it, where can I find the part? I have looked everywhere. Kema
  • 298 Answers
Have you tried eBay?
Posted on Apr 16, 2009
Why won't the hood latch all the way?
Try using lubricant on the latch, if that isn't making a difference look closely at the latch mechanism for anything that looks obviously broken. if nothing looks broken try lifting the hood and then prop it up. pull the hood release again and try to close. let me know if you get it latched
Jan 16, 2016 | 2007 Mitsubishi Galant SE Sedan
How can I open the hood of a '97 Jeep Cherokee when the rod that pops open the latch is disconnected under the hood?
some times pulling the cable sheath from the side as person 2 pulls lever gets it open (not snapped cable, but stretched)
well , that can be hard. (snapped)
its just a cable. so the tech looks at that.
he sees if the center wire in said cable is broken. is it?
i remove it from lever and pull just it (center) open now?
no, we find it pulls out, and is say 2 foot long. 1/2 normal.
he may see , yes, it is then asks self where exactly
he finds it broken say in the middle. so gains access to that point
and cuts the cable there there , and skins back the sheath,
then pulls the good side center wire, and opens the latch.
now he replaces the cable.
and calibrates it per those words in the FSM.
it has 3 fail modes.
  1. lever broken
  2. cable broken or streatched
  3. or latch broken or needs calibration (adjusted to spec).
the only magic here is the yanking cable at mid span.
while BOB pulls lever. (bob is common mechanics name,a joke?)
LOL
Mar 03, 2015 | Jeep Cars & Trucks
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Hood latch won't latch when closing
Raise hood,have some one go pull hood latch and you look at latch and see if it releases,if it doesn't then cable may need replacing,I would'nt completely shut hood cause you may not get back open,also check hood latches bolts and latch for something bent or broken.
Sep 21, 2012 | Chevrolet Silverado 1500 Cars & Trucks
I have a 2006 Saturn Vue. The front passenger
there is a spring inside the door lock that makes it work this spring is most likely broken try spraying lubricant on the lock just in case its binding ,but it seems like you will have to replace the lock mechanism
Feb 07, 2010 | 2006 Saturn Vue
Drivers door is locked and won't open. How can I
It is Very Dificult but the Door Pannel must be removed to gain access to the Lock and Latch Mechenizm
Dec 26, 2009 | 1995 Toyota Camry
Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Feb 15, 2009 | KitchenAid KUDR25 Dishwasher
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Acer Latch is broken
On most notebooks, there is a VERY small return spring (smaller than a spring from a ball point pen) on the latch that tends to break.
Apr 20, 2008 | Acer Aspire 5102WLMi Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
