Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Fridge side quits working
2 yrs old and fridge gets warm. Freezer still works fine.
  • kdsmith890 May 05, 2009
    It appears that thefreezer side begins to freeze up and the refrigerator side stooops working.
    Problem Solver:
Im having the same problem
Posted on Apr 17, 2009
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
Dec 29, 2014 | Kenmore Refrigerators
2 yrs old fridge just warm but the frezzer is fine
if your fridge side is warm and the freezer side is still cold you almost always have a defrosting problem. you can check the back wall of the freezer to see if ice is forming there and behind the back wall. if it is real thick you have a defrost problem. you can ohm out the heater just check to see if it has continuity the deforst thermistat(also called a bi-metal) is bad it will usually be popped up on one end. and lastly if your defrost timer is bad you can manually advance it with a straight screwdriver until it clicks and the fans stop. if the fridge starts defrosting you know the timer is bad
Apr 23, 2010 | KitchenAid KSRB22FKSS Side by Side...
Fridge and freezer works fine-not iced up but
Ya, if compressor is working cond. fan also works. Reduce thermostat sett.
Nov 10, 2009 | Amana ABB1927DE Bottom Freezer...
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
Freezer cold, fridge warm
Hi, You have a self defrosting problem.
Remove the rear inside freezer panel and check continuity on the defrost element and bi-metal switch.The bi-metal has to be tested cold. If there is continuity on both parts, you will need to change the defrost timer.
The most common part that goes bad is the element. I hope this helps you. Please leet me know if I can assist you further.
Vic
May 28, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer is working good but the fresh food side is warm.
I will need to get a little more information to help you better. Sounds like the defrost timer is bad but I will need a number like for example 915.125869
Let me know, Thanks Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Feb 27, 2009 | Kenmore 53642 / 53644 Side by Side...
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Fridge not cold, freezer on bottom works fine
you have defrost problem 1 timer defrostthermostart or heater
Jan 19, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Freezer quit however fridge appears to be cooling...
if there is a fan in the freezer; in that is not working then yes OR the thermostat has gone. But the unit only has one compressor and if the fridge is working it is normally a good sign.
If you where really concerned you could call a domestic refrig tech they could fix it.
Hope that this helps
Jan 11, 2009 | Kenmore 50522 / 50524 Side by Side...
Fridge side by side and freezer not cooling
The fridge is working again and I don't understand why. Thanks anyway all is good.
Jul 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
164 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
