Question about Tappan TGF320 Gas Kitchen Range
I want to know if i can change the yellowish color of my stove top to white somehow and if i need to are the sides paintable to white Jean It is a tappan gas range.
    President:
  • 1,865 Answers
You can purchase white arcylic appliance paint in spray cans. Simply use a piece of sandpaper to 220 grit to rough up the surface before you paint them
Posted on Apr 16, 2009
I have propane. Is my range set up fpr natural gas or propane and do i need to change. I'm having issues with my oven
without knowing your model number or mfg it's tough to say 4 sure but i can say that most common mfg do offer a propane conversion kit to use there gas stoves on bottle gas , most often it's a new regulator to install
Jan 08, 2015 | Kitchen Ranges
Hardwire fridigaire electrolux gallery series stove top. Hooked black and red from branch to black and red from stove top. Neutral side hooked green and white from from stovetop to neutral side. Ho
Should be correct. Maybe it power supply problems.
Have you verify that the line you connected are receiving power on both hot legs ( Red and Black) and that neutral White wire) is actually connected to ground? Use a voltage meter and ohm meter to to do your tests.
Nov 16, 2014 | Kitchen Ranges
There is always a yellowish staining on the top part of the oven door, door handle and vents after self cleaning. I've tried bleach, sos, Mr. Clean Magic pads and it barely removes it. What do you...
the yellowish "staining" is a result of a bad seal. Since it is heat changing the color of the surface, you would probably have to do some damage to remove the discoloration, either like a soft abrasive scrub or other, bleach will not fix that.
Sounds like the cleaning cycle could be too long or otherwise too hot for too long? Perhaps a wipe down with a damp cloth to the interior of the oven prior to a self clean to remove any loose material may help.. Also if there are any other vents for this oven (say under one of the burners of the stove top) make sure they are kept free and clear of any blockage of air flow..
Best regards
Ck
Mar 12, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Need to know where to check my brake fluid at under the hood
The brake fluid reservior is located on the driver side, toward the back of the car. Look for a white or light yellowish colored plastic tub with a black cap on top. There are some marks on the side showing a minimum and maximum fill level. Make sure to use the correct fluid for your car, and do not use the brake pedal with the cap off.
Mar 11, 2011 | 1999 Dodge Caravan
Picture is yellowish and dim hard to see during daylight
you will have to change the coolant under the blue and maybe the red crt lens
Apr 18, 2010 | Samsung PCL545R 54" Rear Projection...
The fan runs and then shuts off. The light on one dial ''blew''
the white wire from the stove top goes to the green wire or nuteural, the red and black go to the hot wires I had the white wire from the stove top going to the hot wire and I had the same problem as you. am lucky I did not burn up my motor.
Dec 06, 2008 | Jenn-Air JED8430 Electric Cooktop
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
No white color on my hp lcd monitor
check the output of your power pack .you are having voltage drop in your output supply
Oct 18, 2008 | Computers & Internet
Paint had gone on surrounding the clock area
You can get spray paint in stores. Here is the kicker. Generally speaking Ovens and stoves have a baked on finnish. The problem is going to be getting a (And this is the key words) "High Heat" paint that matches the color of your stove. Most paint stores have "High Heat" in black red or silver to paint Bar B Q's with. However most do not have a multitude of colors that kitchen appliances come in. If your stove is one of those colors then problem solved go to the local paint store and pick it up. If not try looking at automotive paint stores for the similar color. In an automotive store you will look in the isle for Engine paint. If you can not find a paint that matches the color in High Heat, you could try an appliance epoxy. The thing is that is usually used on refridgerators, washers, dryers etc and not recomended for stoves. Try a small spot and monitor it. If it begins to peel my recomendation would be replace the stove as coatings beyond that will start to become more pricey than a new range.
Aug 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Tappan TGF320 Gas Kitchen Range Logo
99 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De GO PATS
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
