Question about Samsung HL-S6188W 61" HDTV
TV model HLS6188W start to shutting off all the time.
Is the bulb ready to go out?
I have this telvesion and after 3 years of 4-6 hours of gameplay, my bulb is still good. I did have the problem you are describing and fixed it by removing the panel on the back of the television where the lamp is located, reattached it and no issues.
Posted on May 18, 2009
  • 10,594 Answers
If TV lamp has not been changed in last 2 years then most probably its Lamp issue in TV and requires lamp replacement.
Posted on Apr 16, 2009
TV stops video and audio for about 5 seconds
This model does have some issues, you can try on it to either remove it and a box if used for power for several minutes and then power back to see if that helps.
Soft reset with set on should (using original remote) be Menu, 1,2,3 and enter.
Dec 20, 2012 | Mitsubishi WD-73737 73 in. HD-Ready TV
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
I need to know what bulb to order for my RCA HDTV Model #D52W20. Do not know the model number for the bulbs for replacement. Can you help please?
that model doesnt have any replacable bulbs. there are no consumable bulbs or lamps for that model. what is the problem with the tv does it not turn on? that model was notorius for power supply failures where the tv would try to power on and get a green light on front and come on and off 3 times.
Jan 06, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a samsung tv model #hln4365w. it turns on but the lamp light blinks and cycles through about 3 times, then the three lights come on including tempature and all shuts down. Is this the sign to...
The projection lamp has not been replaced like 1 1/2 or 2 years and tv on and used like 4 or 5 hours a day on this tv?yes,than the projection lamp life is over.Require a new projection lamp.
Sep 13, 2010 | Samsung HLN4365W 43" Rear Projection...
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
We have an lg tv model # ru60sz30 and it shuts off randomly. Does this mean the buld needs to be replaced?
possibly there should be an option to look at the bulb life if youre hovering around 2000hrs its probably time to change the bulb
May 21, 2010 | LG RU-60SZ30 60" Rear Projection...
Samsung DLP 62 inch turns off by itself after being switched on
take off the lamp access door on the back and find the safety switch that the door pushes on. unplug the connector from the switch and put staple into the connector to short out the cable. Switch is probably bad. worked for me. same problem.
Apr 07, 2009 | Samsung 61" Slim-Depth DLP HDTV
START AND SHUTDOWN
Hello Mr. Bond.
I believe that you have a rear projection TV where the light from
a powerful halogen light bulb is focused onto a micro-prism
viewing screen through a Liquid Crystal Video Chip.
The light-bulbs have a finite life, degrade with time and eventually
burn out. It is likely that you have a burned out light bulb.
Replacement light bulbs range from about $150 to $250 from
the dealer, depending on the exact model.
The bulbs are somewhat cheaper by mail order from the Internet,
if you can wait that long. Also, some bulbs are available without
the integral mounting bracket, further reducing the cost, but
skilled hands and careful handling is required.
Never touch the glass of a TV light bulb with your bare fingers.
The bulb runs very hot, and residual sweat from your fingers
may cause th bulb to crack and explode.
(use gentle white cloth gloves when handling the new bulb.
I believe that bulb just burned out on its own, and this has
nothing to do with your attempt to connect a DVD player.
On my TV (Sony 60"), a flashing green light indicates a
normal power-up/ bulb warm-up cycle. If the bulb fails to
respond, the TV will detect a bad bulb and shut off again.
Apr 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Samsung HL-S5679W
i GOT TIRED OF FIGHTING IT, AND JUST LEAVE IT ON ALL THE TIME, SINCE MINE WILL TURN OFF CONTINUOUSLY FOR THE FIRST 3 HOURS OF TRYING TO TURN IT ON, SO BY THE TIME IT IS ABLE TO STAY ON FOR THE DURATION, YOU DON'T NEED IT ANYMORE, SO JUST LEAVING IT ALWAYS ON, IT IS READY WHEN I WANT IT. WHAT A PAIN.
Aug 10, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S6188W 61" HDTV Logo
199 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
