Question about Karcher 2500 PSI Pressure Washer
2005 psi pressure washer step by step instructions
Hi
im trying to find out how to use this power hose to wash the car i want to be able to wet the car down then foam it and rinse it again with clean water and the instructions arnt very clear
any help would be appreciated
  • 88 Answers
If you have a Makita (you just said 6221d) then you can lube it with Bosch Grease, part number 1615430005. A tube of this can be obtained from ereplacementparts.com where 45ml will cost you $6.33
Posted on Apr 16, 2009
What kind of soap is used in a pressure washer
Any water soluble washing agent ... depending on what you are washing. Some are not good if you are washing siding and will get the windows wet.
Oct 10, 2014 | Simpson PS3200 Powershot 3200 Psi Direct...
Washer error on rinse cycle
E11 means the Fill time is too long. There are a whole bunch of tests to perform - but the easiest is to replace the hoses going into the machine - I had the same problem and tested my hoses - they looked fine - but my machine would do this every so often - turns out my hoses had "check valves" that were a safety design to prevent freeflowing incase one burst.....well the valve was going bad. Replaced both hoses - never had a problem again. But anyways... here are the other tests...
1. Is the incoming water flow normal?
Yes. Go to step (4). No. Go to step (2)
2. Are the incoming water faucets turned completely on?
No. Turn water faucets on. Yes. Go to step (3).
3. Is the incoming water pressure above (30) psi.
No. Have customer correct pressure problem.
Yes. Check for kinked or blocked incoming water hoses, clean
the incoming water screens. If problem still remains, replace the
water inlet valve assembly.
4. Does the fill water continue enter the washer?
Yes. Go to step (5). No. Go to step (6)
5. Remove power from the washer. Did the water fill
stop?
Yes. Go to step (6) No. Replace the inlet valve assembly.
6. Good models, check the pressure switch.
Pressure switch checks good. Go to step (8).
Pressure switch checks bad. Replace pressure switch.
7. Better models, replace the pressure sensor.
If this did not correct the problem, go to step 8.
8. Replace the control board.
Good Luck!!!
GOOD LUCK!!!!
Apr 05, 2014 | Frigidaire ATF6000ES Front Load Washer
E10 error code on Frigidaire affinity how to repair it
Your fill time, water fill time, is too long. Have a professional complete the following:
. Is the incoming water flow normal? Yes, go to step (4). No, go to step (2). 2. Are the incoming water faucets turned on? No, turn water faucets on. Yes, go to step (3). 3. Is the incoming water pressure above (30) psi? No, have customer correct pressure problem. Yes, check for kinked or blocked incoming water hoses, clean incoming water screens. If problem still remains, replace the water inlet valve assembly. 4. Does the fill water continue to enter the washer? Yes, go to step (5) no, go to step (6). 5. Remove power from washer. Did the water fill stop? Yes, go to step (6). No, replace the inlet valve assembly. 6. For Better models, check the electronic pressure sensor. For Good models, check the pressure switch. Pressure sensor checks good. Go to step (7). Pressure sensor checks incorrect. Replace pressure sensor. 7. Replace the Main Control Board
Aug 16, 2012 | Frigidaire Affinity ATF7000ES Front Load...
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
Will not build presure at pump just like a garden hose
run some oil in inlet/outlet/or/oil then connect hoses back what is going on is when you run it then store it the seals dry up keep it oiled when storing.
Jan 15, 2011 | Northstar Gas Powered Wet Steam & Hot...
Sears 2600 psi power washer
there should be a low presure tip for dispensing wash cleaner or if you have an adjustable wand turn it to low presure setting also make sure the suction tube is open some have a adjustable filter...good luck
Jul 25, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
My high pressure 2400 psi hose blew out.
Hi cwsales:
Sorry, the pressure will be too much for a your mend to work. You will just get wet. A professional hose repair shop is your best bet, or a new hose.
Jul 14, 2009 | Campbell Hausfeld Garden
Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Apr 24, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
198 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
