Question about Refrigerators
Refrigerator leak inside
My refrigerator is leaking inside. Ice is forming in the air cooling ducts and melts and water slowly fills the bottom of my refrigerator. The freezer is on the top and the frig is on the bottom. Any advice would be greatly apprecieated to fix this problem.
  • bill1951 Mar 25, 2008
    Cleaned coils and everything underneith and in back.
    Still leaking.
tech master
  • 120 Answers
SOURCE: My GE Profile makes ice but then the ice cubes melt!
repl main board and make sure your out let is properly wired and grounded those main boards are sensitive when not grounded
Posted on Oct 31, 2008
  • 66 Answers
SOURCE: ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Posted on Nov 15, 2008
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    SOURCE: GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
    i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
    Posted on Apr 25, 2009
    Sea Breeze
    • 4655 Answers
    SOURCE: Ice build up on bottom of freezer. Water leaks out.
    Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
    Posted on May 21, 2009
    Ice in one side if top freezer and water ending up in bottom of fridge under crisper
    Check to see if your ice maker is leaking. If it is not, or if you have no ice maker, you'll need to unplug the refrigerator for several hours to allow all of the ice to melt inside, mop up all of the water from the melted ice, then make sure that the inlet ports in the freezer are not obstructed by plastic food packages or anything else, so that air can flow freely within the cooling channels between the 'fridge and the freezer. (It sounds like ice has built up in the duct that runs between the freezer fan and the refrigerator compartment, usually caused by the vents in the freezer being blocked by packages.)
    May 11, 2015 | Whirlpool Refrigerators
    Water from the ice maker overflowing into the ice container. Water also running down the inside of the freezer onto the bottom forming a thick block of ice. It melts,and flows to the floor.
    Sounds like the water valve For the ice maker fill is leaking. these are solenoid type usually found at the back bottom outside of unit. turn water to this valve off at connection in wall . You can have that valve replaced
    Jun 22, 2011 | Refrigerators
    Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
    Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
    Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
    Water leak from ac
    this is called condensation from the heat vaporator as the acc is cooling the car inside the heat is taken out from the inside of the car ice form s on the vaporator and the blower fan melts the ice
    Aug 08, 2009 | 2003 Dodge Caravan
    Ice forming in the bottom of the freezer
    Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
    Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
    Water leak @ bottom front left with water turned off
    this quite simple, inside the freezer compartment lower half there is a removable inspection cover, or what you may call the rear interior wall. remove this cover/wall and underneath the cooling coils is a drain hole for the defrosted water to escape to the pan located under the refrig. This hole is obviously blocked with some object, possibly just ice. As it is blocked the defrosted ice in the form of water cant exit the normal way so it is over flowing onto the freezer floor. everytime the defost element comes on more water will leak. solution is to clear the drain hose possible with hair dryer , or gently running a firm but flexible plastic tube through the drain tube to push any blockage on through. This has to be done very slowly and carefully.
    May 19, 2009 | Jenn-Air JSD2789GEW Side by Side...
    Water collects in bottom of freezer forming ice which leaks.
    your drain hole is frozen over u need to unthaw with a steamer
    Mar 18, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
    Furnace ices up,lines ice up,water condensation leaking in to duct work
    1.check filter if really dirty change
    2. check Refrigerant if low get charged by a tech
    3. check the evaporator coil if dirty clean
    Oct 16, 2008 | Heating & Cooling
    Ice maker leaking
    Sometimes the frozen chunk of ice in the back of your ice tub is caused by the tub being overfilled. The ice cubes pile up so high that they come in contact with the defrost heating element in the bottom of the ice maker. This melts the already formed cubes and form a blob of ice in the rear of the tub.
    If the "icicle" is forming even when the tub is relatively empty, then it is probably a leaking solenoid valve. This is an electric water valve that opens and closes according to demand. Like any valve, it has seats that eventually leak, especially in areas with hard water. This will need to be replaced. Water filters go a long way in increases the usefaul life span of the valve and will also improve the ice quality.
    Dec 02, 2006 | Kenmore 53642 / 53644 Side by Side...
    Refrigerators Logo
    275 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
