PC does not communicate with external Valitek Travan TR-4 drive
The power and data cables to the tape drive are good. Other connections have been checked. The fuse in the drive is good. The motor in the drive runs, so the drive is getting power. The operating system of the PC is Windows 95 and the Valitek software runs under DOS. We have valuable data on a tape that we would like to recover. What are the most likely reasons that the PC can't communicate with the drive and how can we fix this?
<p>Travan 40 tape drive, manufactured by the leading data
storage and backup device manufacturer Quantum, uses the tape storage business
to 40 gigabytes of data. It can be installed on any Windows computer, and works
as an additional unit similar to a CD-ROM or DVD-ROM. Like a tape of age,
Travan 40 used with the recording heads for data storage on tape. These heads
have to be cleaned, and Quantum recommends using a cleaning tape.<br />
<p> <br />
<p>1. Turn on the computer. Remove the cleaning cartridge of
your case.<br />
<p><br />
<p>2. Insert the cleaning cartridge into the Travan 40 drive,
with the metal plate down. Gently push the drive mechanism that pulls and keeps
everything in the device.<br />
<p><br />
<p>3. Look at the LED on the drive Travan, should stop blinking
and turns off in about 8 seconds. Note that the LED will remain on the
cartridge is used more often than not meant to be used and, if so, remove it
and put a new cleaning cartridge.<br />
<p><br />
<p>4. Slide the unit Eject button and hold and pull the exposed
sides of the car once the disc is ejected.<br />
<p><br />
<p>5. Record the date on the label of the cleaning cartridge
with a marker pen so you can track when your Travan 40 drive yet again and how
often you use the cartridge.<br />
<p><br />
<p>6. The return of the cartridge cleaning your plastic box.<br />
<p><br />
<p>7. Repeat the process of cleaning every week if your drive
Travan more than 3 hours per day, or every month if you use it with less than 3
hours per day. Clean it twice if you have your computer in an area with a large
amount of dust, like a room without air conditioning or a warehouse.<br />
If the machine hasn't been altered in all those years, retrieving the data shouldn't be a problem. If I remember correctly from my days with one of those, the driver software made the tape drive appear as any other drive in Windows so it was just a matter of copying data to and from the drive just like any other hard drive in the system.
You will have to load a driver for the Travan drive, if windows server 2000 sees the tap drive you could use NTbackup.exe to configure a back-up here is a link to read more about it. http://support.microsoft.com/kb/237310/
The STT320000A is IBM version? some IBM version STT320000A will rewind the tape when inserted. But It can recognize the media after rewind. If can't, try to used the cleaning cartridge or change one new media. regards
