Question about Sony PlayStation 2 (PS2) Console
I have a PS2 that is having some difficulties....
Some of the games load other don't.. the parental control is at it's highest level. Played 300 on it the other day...No rhyme or reason to the games it plays. So M's load others donot.. Do I need to have the laser fixed?.. I've cleaned the games and the unit.. what can I do???
You dont need to replace the laser but the problem seems tricky to fix
Posted on Sep 16, 2007
SOURCE:
Remove parental controls PS2 brick
enter 7444 in the parental controlls password box to reset the password and controll levels
Mar 07, 2014 | Sony PlayStation 2 (PS2) Console
Forgotten pin for wii. have confirmation no
wii pin master reset
http://www.nintendo.com/consumer/systems/wii/en_na/settingsParentalControls.jsp#reset
  1. Access the Wii System Settings (how to).
  2. Click on the blue arrow to reach the Wii System Settings 2 menu options.
  3. Choose "Parental Controls" and select "Yes."
  4. Enter the 4-digit PIN and select OK. If you have forgotten the PIN, select " I forgot" to answer the secret question. (Answers to the secret question are case sensitive.) You will now be in the Parental Controls menu, and can change the following items:
  5. Game Settings and PIN
  6. You can adjust the "Highest Game Rating Allowed" to be played on the Wii console. This setting is based on the Entertainment Software Rating Board ("ESRB") game rating categories. Please note that Parental Controls settings do not affect Nintendo GameCube Game Discs.
Feb 27, 2011 | Video Game Consoles & Games
I cant unlock my ps2 console to watch a region 1 dvd and ive tried some unlocks but they wont work
make sure your console has the ability to read region 1 discs in the first place.
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs.
If you forgot the parental control code and you need to unlock that, though, then try this:
1.Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under
custom setup.
2.When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3.The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4.Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Jan 26, 2011 | Sony PlayStation 2 (PS2) Console
How do you take off parental control on a ps2
Courtesy of Yahoo Answers:
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Sep 08, 2009 | Sony PlayStation 2 (PS2) Console
Ps3 parental control
no set it to the highest lvl maxed it gives you total acess then if you set it low thats whats causeing your problem : )
Apr 12, 2009 | Warner Bros. Interactive Lego Batman
I need the overide code for my ps2 that I brought used
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under GA_googleFillSlot("TL-IMU-Article"); custom setup.
Nov 18, 2008 | Sony PlayStation 2 (PS2) Console
Changing parental control
Start the PS2 up and load the DVD. When it shows the Parental screen select YES. When the Password box pops up. Press the Select button on the controller. Type in 7444. Then your password is reset. It will ask you to enter another password. Do that twice. Allow the movie to start. When it gets going pause the movie, Press the Select button on your controller again. The DVD menu pops up. highlight SETUP. When that setup screen appears go to the 3rd icon from the left. Press X. Then highlight Parental Code. Set the parental lockout level to OFF.
Nov 20, 2007 | Sony PlayStation 2 (PS2) Console
Parental codes
Put a DVD into the PS2 and let it try to load. When the screen says chenge to level four select yes. When the entry window pops up,press the select button on the controller. It should say reset password or something like that. Put in 7444. Then when you rename the password put in 0000. You will have to do it again 0000.
Once the movie starts, not the menu screen, but the movie actually playing, Press Select button again. The PS2 DVD menu should appear. Cursor over to the toolbox or Setup, and press X. Cursor over to the third icon, and press X. Arrow down to PArental and press X. Change the Parental lockout to OFF.
I am not completely sure about the procedure here but the numbers are correct.
Nov 11, 2007 | Sony PlayStation 2 (PS2) Console
Parental levels
Put in a DVD, and press select button to go to PS2 DVD menu.  highlight setup menu. Press X.  go to settings I think, and paretal control is there.  Use password 7444.   Usually everyone sets the password to 0000.  Then when you go into the parental settings, turn the level value to OFF
Oct 11, 2007 | Sony PlayStation 2 (PS2) Console
Dvd parental controls
With a DVD disc inserted in your PS2, press the Select button to bring up the on-screen Control Panel. Press the X button to select the Setup icon. Use the directional pad to reach the "Custom Setup" menu, and press the X button. Move to "Parental Control" and select with the X button. A window will appear asking you to enter a four-digit password. Enter your choice of password using the number buttons that appear then enter it again for confirmation. You're now able to set the Parental Control level using the "Region" and "Level" options, and change your password
Aug 19, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
