Question about Car Audio & Video
I was wondering which wires are which to hook up an after market stereo in my 1991 plymouth laser. i need to know what are the power wires and the speaker wires on my stock wire harness.
  • tfischer303 Apr 17, 2009
    thank you for the help.
  • 5,660 Answers
I don't have the exact wire pinout, but I can offer you a generic method. Usually wires in an automotive wire harness that are Red, are power.
I would suggest you buy a cheap multimeter, (If you don't already have one), and set it to the DC volts-50 volt range. They have multimeter's that are relatively inexpensive. $10 or $12 dollars.
There will be a Red lead to a probe, (Positive), and a Black lead to a probe. (Negative) Hold the Red lead to the red wire. Touch the Black lead to any good ground. Any clean of paint, metal surface on the car. The needle should go up to 12 volts on the DC scale.
Ground wires are generally Black or Green. Should you see a Green wire with a stripe on it, this is not a ground wire.
Wires that are of a solid color and have a stripe on them, are usually speaker wires. They will be in pairs. There should be a wire of a solid color with a stripe on it, and a wire of the same color, but no stripe, to make up one pair. One pair is for one speaker. For example:
Blue color wire with a White stripe, and a solid Blue color wire.
There may be two pairs of wires, or four pairs. Two speakers in front, two speakers in back, for the four pairs of wires.
After you find the power wire, and have it attached to the stereo, plus a ground wire, I suggest you make sure ALL the other wire ends are not touching each other, on the stereo. Put a small piece of Black electrical tape on them.
Take one pair of speaker wires, from the car harness, and attach them to the stereo. Turn the stereo on, and see which speaker wires you have. Move the Front/Back, and Left/Right controls.
Now it's just a matter of finding out the correct hook ups for those wires. Match them up.
Posted on Apr 16, 2009
I have a 2001 ford focus se and the previous owner had a stereo just taped together with the wires from the car . The wires are just sticking out and i bought a new one and i need to know what the colors...
a reputable car stereo place will sell you a wiring harness for your vehicle and after market stereo, that tells you which color wires to hook to what.
Oct 21, 2013 | Cars & Trucks
I hooked up an after market stereo and now my speedometer lights don't work. Know why? On my 01 echo.
the bulb could have been bad, yet the aftermarket stereo wiring takes voltage from your dash, hence the illumination/dimmer. really dont need those wires. they hook up to your dash lighting, and draw power from your dash, take those wires out and see if any changes. Id first take the wires out, if no change then the bulbs are probably bad.
Jun 08, 2011 | 2001 Toyota Echo
Replacing radio with an after market cd player in a 1999 ford au sedan jjust need to know what color wires what on the car
  • You did not list the model of Ford Sedan you are inquiring about. Here is a link that has quite a lot or car stereo wiring diagrams http://www.modifiedlife.com/request-a-ford-car-radio-stereo-wiring-diagram/ Look at the upper right of the page and scroll down a little bit as I have it on Ford vehicles already. Find the make and go to the year.
  • That being said if I can make a suggestion. I have hooked up hundreds of car stereos in my life. When I pull a factory radio I don't use the same wires that powered that factory stereo to power the after market stereos, DVD players etc. I go into the dash and find suitable wires a little thicker gauge to handle to often more powerful output of the aftermarket stereos.
Regards, Tony
May 20, 2011 | Car Audio & Video
I have a 1991 plymoth sundance putting a after market radio in it i put the speakers in hook them up turn the volume all the way up and the music sounds real low what is the problem please
Sounds to me like the speaker wires may be reversed but then again I'm not perfect, just don't tell my wife that. Anyhow here is the wiring info for your vehicle just to double check. I hope this helps you and good luck.
1987-93 Plymouth Sundance Stereo Wiring Constant 12V+ Pink Switched 12V+ Red/White Ground Ground/Back Strap Illumination n/a Dimmer Orange/White Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Green/Yellow Right Front (+) Purple Right Front (-) Purple/Yellow Rear Speakers 5" x 7" Side Shelves Left Rear (+) Brown Left Rear (-) Brown/Yellow Right Rear (+) Blue/Red Right Rear (-) Blue/White
Mar 28, 2011 | 1991 Plymouth Sundance
Red,yellow and blue with stripe hooks to what into harness
some decks have a solid blue for power antenna and blue with white stripe for amp turn on. if you have neither a power antenna or amplifier, i would not worry about connecting those two wires. do makes sure they are capped off and have no bare wires showing, as they are hot when the stereo is turned on.
May 05, 2010 | Pioneer DEH-P2900MP CD Receiver...
1991 plymouth laser rs strange light comes on then turns off.
I would check the engine coolant, It should be filled to the COOL LINE when engine is cold.
Jan 05, 2010 | 1992 Plymouth Laser
I have a 1998 Plymouth Breeze and i want to know whats the best CD Ipod car stereo to put in it
hi im pretty sure that your model is compatible with any after market stero its all up to your prefrence
Nov 27, 2009 | 1998 Plymouth Breeze
Auto battery keep going down on my 1991 Plymouth Laser
Unhook the power terminal possitive + hook a 12 volt light to it and the battery close all doors and turn off all switches begin removing fuses from the fuse pannel till the light goes out this is your drain.
Aug 27, 2009 | 1991 Plymouth Laser
Speaker wires colours in dashboard of 1991 previa
http://www.installdr.com/Harnesses/Toyota-Wiring.pdf  Here is a link that should help you get some sound booming. Keep me posted, be glad to help.
Jun 24, 2009 | 1991 Toyota Previa
I am installing an after market stereo deck into a 2004 Chevy Cavalier but I am not getting any power. From my research I need to hook the deck up to the vehicles ignition harness but I do not know where...
ok now this is fun i had a good ole time putting my after market raidio in on my 04 with out the $300 harness that the sterio shops wanna charge a arm and a leg to install you need to run your 12v power source to the igniton fuse its farly simple if you need picture diagrams i can deffianatly post some pictures showing you exactly how to wire it up bc trust me i was mad enuff trying to get my stereo in so i wouldnt mind helping some one else out on getting it installed bc its frustrating not knowing how to do it
Jul 19, 2008 | 2004 Chevrolet Cavalier
Car Audio & Video Logo
113 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
