Question about Compaq Armada 3500 Notebook
My computer is sayin non sysyem disk what does that mean
  • sexy_sweet89 Apr 16, 2009
    its sayin non system disk or disk error
  • JDTec
    JDTec May 11, 2010
    It means that there is a problem with the hard drive. The unit is not seeing the OS, hence it will not boot.
  • 326 Answers
This means that your system can not find a suitable drive to boot off of.
It could mean the absence of a healthy, physically functional drive with an OS, or a version of windows, on it.
It could also mean that the systems drive is not well connected.
The check the physical connection of your drive:
You should inspect the bottom of your computer for any access panels and/or symbols that may look like a stack of circles, a short 3d-cylinder, or just the letters "HD" "HDD" "Hard Drive" "System" these will indicate that the systems Hard Drive is located behind this panel, carefully remove the screw holding the panel and press lightly on the edges with steady towards the connection, most likely this pannel will be on the edge of the laptop, on the side, but this varies greatly.
To check where your computer is attempting to boot from:
While powering on your machine you should see "System Setup" or similar message with a key to press. This key should be F10 for your system
Consult the screen and press this key. You should be in the system setup or "BIOS Setup" This is where your computer hardware settings, like what to boot from, are set.
Reference the bottom of the screen for instructions navigating around Check around for boot options, it should have its own menu.
At the Boot Options/Settings menu make sure HDD/Hard Drive/IDE(any of these may be listed, but theres only one to chose from) is selected for 1st Option.
If you have assured the connection, and where the computer is attempting to boot from is infact the Hard Drive, then there may be a lack of system software on your disk.
You would have to consult your owners manual on restoring your system using disks that may or may not have been provided. The only other option after that would be to purchase a version of the Operating System you wish to use, Windows XP, etc. or consider a less-user friendly option like an Open Source Operating System like Ubuntu or Debian, or other various "Linux"
These steps will lead you through the troubleshooting process, so you know where you stand.
Let us know if you run into any bumps.
Posted on Apr 16, 2009
  • Compaq Master
  • 19,396 Answers
That means that either the system is corrupted or the hard disk is faulty.
You will need to reinstall the system using a recovery disk or a generic windows system disk.
You can purchase a full recovery disk from HP for about $20.
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
My laptop model is hp compaq nx6120..Its showing the error as non-system disk or disk error replace and strike any key when ready...hw to recover this error?and also cant able to view the bios settings...
You may have a defective Motherboard (BIOS or CMOS chip to be specific). Normally, a non-system disk error can be attributed to a failing hard drive. But since you mentioned that you cannot access the system configuration, that means your BIOS is not able to see your bootable device anymore. You may need to have your computer serviced which means a motherboard replacement.
But before you send your computer to a service center, try to discharge flea power first. You may be surprised how many issues it can resolve. You can do this by removing the battery and the AC adapter of your computer. After doing this, hold the power button down for at least 5 seconds. Reconnect the components, and then try to turn your computer on. Hopefully this works so that you don't need to spend as much. The cost of a motherboard replacement would be more like replacing your whole system. Good Luck!!!
Jul 01, 2011 | Computers & Internet
My e-machine w3410 gives me a disk boot error insert disk and hit enter what does that mean
You probably have a non-bootable disc in the CD drive - when the computer powers up, your BIOS's first boot device is probably the CD drive and since it has a non-bootable disc in it, it can't boot. Remove the disc and re-boot your computer.
Dec 22, 2010 | E-Machines eMachines Desktop PC
My syastem was working properly since five month don"t no suddenly what happned after swiching on the computer its showing like DISK BOOT IS FAILURE, INSERT SYSYEM DISK AND THEN PRESS ENTER ....... i amnot...
this means, there is no bootable disk detected. Make sure there is no floppy drive inserted to the system and remove external storage devices, then try to remove and reconnect the hard disk. Make sure your boot method is set to use the hard disk with your OS installed. If this does not work, you may have to reinstall your operating system. If this fails, it may indicate a failed hard disk and you may have to get in touch with your vendor for warranty replacements if needed. hope this helps.
Aug 29, 2010 | Computers & Internet
Freeze on gateway logo. does not respond to any of the function keys (F8, F10, F2...)
Possible a bad hard drive. Do you have a restore disk? If not you might have to reinstall the operating system. They do make recovery disk, you might want to check with a local computer shop to see if you can purchase a recovery disk,,,,Darren
A lot of times the master boot record will become corrupted and it cannot find the operating sysyem.
Oct 15, 2009 | Gateway GT5228 (7156) PC Desktop
My laptop doesnt work anymore suddenly!
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Apr 10, 2009 | Acer Aspire 4720 Notebook
Its sayin to wipe off with a cloth
basically it means the disc is dirty, clean the disk and blow into the xbox tray to remove any sittin gdust that might effect it, mine did the same thing
Dec 02, 2008 | Video Game Consoles & Games
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
No disc drive
its a service isue
Dec 29, 2007 | Acer Aspire 3680 Laptop
Compaq Armada 3500 Notebook Logo
90 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
