Question about Kodak EasyShare DX4530 Digital Camera
Screen is completly white
My camera was working fine today but then when I went to take a picture, the screen was completly white. When I push the menu or review or anything it still is a white screen. So I put it on the docking station and to se if it took any of the pictures that I shot and it did. Please help thank You
    Sergeant:
  • 274 Answers
There is a micro connector inside that has electrical traces so small if they get misaligned in anyway you get the result you are seeing. You can try to fix it your self if your are mechanical inclined and very patient. Otherwise take it to a repair shop to be fixed Remove the batteries. Remove the small screws around the case and pry open the camera with the lens down, LCD up. Careful not to damage the alum bracket with holds the LCD, remove the two or three screws that hold it down. VERY carefully lift the LCD and you will see the connector attaching a thin membrane lead to the main PCB. That connector is fragile! It has two very small tabs on each end of it but in fact it is one long piece. Push each end outward from the connector and membrane lead comes loose. carefully wipe it clean and re-insert it. Re-align the membrane carefully. Push the locking mechanism back in place and reassemble the camera. Before putting the outer case on you can power up your camera to see it you fixed it. If you didn't....it goes to the repair shop. Don't do this if it is still under warentee.
Posted on Sep 16, 2007
6ya staff
SOURCE:
No picture on back of camera 'screen'
Hi Karen_Earl I can't believe that this advice I found here todayon this site actually worked !! just passing it on. I got the evil white LCD screen today and then found this advice here: turned it off - I smacked the top of the camera afew times and when I turned it back on it worked fine!! who would have thought there was such an easy, instant and cheap solution to what I thought was an expensive or terminal problem! Thanks to Jada 1234 for posting this last year! !
May 26, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
LCD Screen remains black
Hi!
Have you tried pushing the DISP button while taking pictures? It's on the right from the LCD.
Tom
Aug 02, 2009 | Canon PowerShot A720 IS Digital Camera
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon S2 IS - LCD screen is white after taking an outside picture
the image is all white or has lines through it.Definitely sounds like a repair issue, and has been a previous problem with the camera in the past. There is a defect in the sensor of the camera, and happens quite frequently in this model. I would try and contact Canon about it, and see if they'll repair it for free. If not, its probably going to cost more than the camera is worth to repair it.
Mar 24, 2009 | Canon PowerShot S2 IS Digital Camera
My DSC-T1 Camera only takes barely visible pictures
Its problem of ccd imager in your DSC-T1 camera and that part will be replaced.
Sony announced free of cost repair for subject problem. Click Sony CCD Support for details.
Oct 01, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
A White Screen!
I had the same problem a few months ago. Best bet is take it to get it fixed. If you still have a warrantey it won't cost you a thing. Good luck!
Feb 29, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Camera wont turn off
Remove the battery. The same thing happened to mine and once I put the battery back it worked fine.
Dec 31, 2007 | Vivitar Vivicam 5105s Digital Camera
My samsung digimax 503 has a white screen!
Oh my gosh this really works! Our screen went white, we hadn't dropped it or anything. The camera still worked fine but we just couldn't see what we were taking a picture of. We tried this solution and now we can see the picture through the screen perfectly. THANKS for posting this!
Nov 09, 2007 | Samsung Digimax A503 Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
56 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
