Cars & Trucks Logo
Posted on Jul 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio wont' shut off when drivers door opened
Ever since I had my oil changed and reset the ''replace oil soon'' light, my car radio now continues to play when the engine is shut off and the doors are opened. It used to shut off as soon as the drivers side door was opened, but now it keeps on going. I reset the factory settings, but it did nothing. How do I set the duration the radio will play to shut off when the drivers door is open? It's a factory radio.
Jeff Armer
Level 3:
  • Chevrolet Master 15,575 Answers
  • Posted on Jul 24, 2017
Jeff Armer
Chevrolet Master
Level 3:
Answers
15575
Questions
Helped
7106660
Points
73899
Try a window ,see if they still work too . RAP relay supply's power for radio windows etc. when key is turned off for ten mins or till a door is open .
5 Related Answers
Anonymous
  • Posted on Jan 24, 2009
SOURCE: my alarm keeps going off
I had the same problem with the alarm, the radio, the dome light staying on the lights left on alarm not going off four trips to the GM dealer who refers to my 2004 cavalier as a "crapalier" I have spent hundreds trying to have this problem fixed and finally figured out a solution which is never ever again in my lifetime will I purchase a GM product and some adavan to caml myself in the knowledge that my tax dollars are going to help this worthless company out. [email protected]
emjem74
scott rimmer
  • 162 Answers
  • Posted on Feb 25, 2009
SOURCE: passenger door won't open
most common problem with replacing door handles on these is that you will encounter allignment probs for main catch which this sounds like. if you attempt to open from the inside then try putting lots of pressure on it till it should give way. once you acvhieve this, try looking at the very end of the door with the catch on. if you take a key and roll the latch till it locks and lake sure it is not too far into the mechanism, dont worry simply pulling door handle will disengage it, but once it is shut like this it is extremely difficult to undo.
Anonymous
  • 25 Answers
  • Posted on Mar 08, 2009
SOURCE: Where is the door contact switch?
Hiya
Check all 4 doors to see what works and doesn't work, be sure the interior domelight switch is set to turn on automatically when any door is open as well try the radio then open the 4 doors to see if it turns off...if your driver's side door don't work as you stated then that should be the door's "at fault".
GM built the door contact switch that's installed INSIDE the door-it's located inside the door striker/jamb area...it require removal of door trim to gain access.
However, you might want to try this visual inspection:
Check the thick wire harness located between the front-left door and door sill frame to see if any wire has been disconnected/cut or tampered with by previous owner.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Mar 12, 2009
SOURCE: when i use to lock the doors on the switch on the
U have a defective door ajar switch.
Anonymous
  • 6982 Answers
  • Posted on Apr 27, 2010
SOURCE: Electrical Problem in 1995 Jeep Grand Cherokee Limited
You co0uld change the module but I don't know the exact location of yours (under the dash) If I was working on it and couldn't get a location, Id take a look at one from a parts house so I had an idea what I was looking for, then start looking. They aren't cheap though so sometimes it's best to have a good shop look it over just to make sure it will fix the problem.
When working, I test everything either with meters, scanners etc or use known good units to check problems. Here, I can only make educated guesses. Electrical parts are generally non-returnable so mistakes can be costly.
Good luck though.
Even though driver door is closed,command screen says Driver Door Ajar.Interior lights stay on,except in drive.Even radio shuts off immediatly after shutting ignition off.Do I need to replace sensor??
Usually the solution to this problem is to use a good penetrating oil and spray HEAVILY the latch mechanism (both doors), let it soak in, and open/close the door 15-20 times-the sensor is in the door and it gets hung up, spraying lubricant on the latches frees it up.
tip
Pontiac service light 1983-01
Firebird
1998-01
To reset the "CHANGE OIL" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and goes out, the system is reset.
Grand Am
1999 -01
To reset the Change Oil light, open the driver's side instrument fuse panel and turn the ignition on. Press the "RESET" button and release. The light will flash. Press the button again and the system will be reset.
Grand Prix
1999-01
Driver Information Center If Equipped). Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the ignition key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on, repeat the procedure. To reset the OIL LIFE indictor if equipped with a Trip Computer: Press the trip MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to be 99 percent.
Grand Prix
1997-98
To reset the oil life indicator, press the "MODE" button until the light next to "OIL LIFE" is lit. Press and hold "RESET" for 3 seconds until oil life percentage is 100%.
Grand Prix SE
1997
Turn the ignition on, but do not start the vehicle. Within 5 seconds, push the accelerator to the floor 3 times. Turn the ignition off. Start the car and the Change Oil Soon indicator light will be reset.
Grand Prix
w/ Trip Computer
1988-93
To reset "CHANGE OIL", "CHANGE OIL FILTER", or the mileage of either on the Trip Compute, continually press the "SERVICE" or "SYSTEMS CHECK" button until the item appears with the mileage below it. Then press the "RESET" button and the mileage will be reset to the maximum value. If you want to reduce this value, hold the "RESET" button down and the mileage will count down. Release the button at the mileage you would like to observe.
Bonneville,
6000
w/ Driver Information Center
1983-91
To reset "CHANGE OIL SOON" or "OIL FILTER" or to adjust the mileage on the Driver Information Center, continually press the "DIC" button until either message appears with the mileage below it. At this point, hold down the button. In 5 to 10 seconds, the mileage will count down. When it passes 0, it will cycle back to a maximum figure. Release the button when the mileage gets to the service interval you'd like to observe. If "CHANGE OIL" or "OIL FILTER" already appears, just hold the button down to reset the mileage. "CHANGE OIL" and "OIL FILTER" are reset separately.
2002 Pontiac Grand Prix - multi-fuse related problems.The A/C keeps shorting out and the garage replaces the fuse. Where is the fuse box for the A/C located? Also, the radio display is dim/non existent...
I can't answer because I have other question open, sorry, but here I send any comments and clues to solve (I hope).
For the FUSE PANEL, location and description, I suggest check the 2000-Pontiac-Grand-Prix-Owners-Manual (page 330 and next). A/C have one "diode". Check it.
About your radio display, sound like a internal problem, keep in mind that the CD is working.
The Security Litgh, its possible that you have any problem with the THEFT system or any aftermark alarm (if you have).
Resetting Oil Service Indicator Lights - Pontiac Grand Prix, 1999-03
Driver Information Center If Equipped). Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL Soon indicator flashes two times, the system is resetting. Turn the ignition key to OFF, then start the vehicle.
Hope helps (remember rated this).
2helpful
2answers
How to reset change oil soon light
if dash digital display bring up oil life display than press the check symbol if standard dash turn key to on position not start than press gas pedal three times start truck should reset if not-- repeat process
2answers
Change oil soon how do you shut it off after youve changed the oil
turn ignition on with engine off press gas pedal to floor 3 times & light will flash then go out.
or if you have menu button on radio press button until reset oil life appears ten press enter
2helpful
2answers
1999 Pontiac Grand Am GT
turn the key to "on" and open the fuse panel to the left of the steering wheel when drivers door is open, hold the "reset" button until the oil light on the dash starts to blink and then push it again, you should hear the chimes and then the light will go off. :-)
2answers
Reset service engine soon light
oil change might not have they obd2 tester to shut
the light go to auto parts chain store like autozone
tell shut it up for you for free
Dome light won't turn on.
my dome light wont turn on at all and i dont know where the fuse is iv checked all my fuses and there fine could it be a capasiter
2answers
How do you turn off the check oil light
usualy by the fusebox on driver side panel open door.. by the side view mirror should be a panel.
9helpful
3answers
Change oil light remains on after oil change and light over license plate does not work after bulb change
To reset the Change Oil Light: Open driver's door and open fuse access panel
Turn ignition key to on (don't crank the starter) Push reset button located in fuse panel When Change Oil Light starts to flash Press and hold reset button until it beeps and light goes off Repace panel
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
