Question about Frigidaire PHSC39EJ Side by Side Refrigerator
Will not stop running
I have frigidaire refrigerators PHSC39EJ. Everytime time the power goes out any come back on at my house. the refrig light is on but if is on cooling I have to unplug it for 15 min then plug it back then it starts to cool but it had to reach the temp it was set on before the power went out before you can adjust the temp again. it somehow got set to -6 but its only getting to -5 so i can set it to -1 and 37 it keeps on running WHAT CAN TO DO?
  • Frigidaire Master
  • 4,654 Answers
Freeze temperature at -5 to -10 degrees is fine. Now because *********** board needs to be reset I'm not sure until I research your model better. Mother boards store memory and decide the functions of your refrigerator. So a complete loss of power to the memory board is understandable. But the price of replacement of a control board is expensive. So if you can deal with this inconvenience I would go with what you have to do to reset the board. I will be digging deeper into this, and if you need me to help you further please let me know. Now if you need to replace the board because this is your point and problem, I will help you replace the board. Thanks, JT
Posted on Apr 16, 2009
Roper model RT18DKXDN10. The refrigerator is running but is not getting cold. Seals around door are good, light goes off when door closes. The refrig is outside on our deck. It worked fine but stopped wkg...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 13, 2010 | Roper Refrigerators
Model phsc39ejsso, I have cleaned underneath fridge, but it is running too warm
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 31, 2010 | Frigidaire PHSC39EJ Side by Side...
Water draining in bottom of refrigerator
Unplug the refrig . Inside the refrig section , remove the 4 screws ( 2 on each side ) and
lower the panel . Disconnect the large plug and remove the panel by pulling froward to
clear the defrost drain hole .Find a food safe caulking or odorless silicon and caulk at the
upper portion where the styrofoam meets the plastic AND on the top center of the styrofoam (
all the way around the large rectangle hole ) so that the styrofoam will seal to the top of
the refrig . When the refrig goes into defrost , the water is seeping between the refrig top
and the styrofoam , causing it to run into the refrig section . When reassembling , be sure
to plug the large plug back into the refrig .
May 28, 2010 | Frigidaire FRT21H8 Top Freezer...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
I have a frigidaire side by side refrig. mod frs26rlecse the evaporator fan don't work I put new one , but the new one don't work neater .the freezer side work but freeze in the bottom , and the frige...
HELLO,
This fridge may be lacking the chemical called freon, a typical coolant agent used in refrigirators, try to replace the coolant, and then let the fridge run some time. It should be back on cooling as normal...:)
Sep 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Tree fell on power lines. power out for 4 hours.
well u have a problem of power supply get it checked by an expert.
Jul 16, 2009 | Frigidaire FRS6R5EMB Side by Side...
Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
Nov 23, 2007 | Frigidaire Side by Side Refrigerator 26...
Refrigator compressor motor
No fuse. Check for retracted pins in molex connectors in back. See if any pins are sticking up farther than others on side of plug where wires enter. If so unplug connector and push wire in. Re-connect and recheck. Also have seen this in connector in console on left ceiling of refig. section.
Nov 15, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire PHSC39EJ Side by Side Refrigerator Logo
155 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
