Question about Yamaha RX-V800 Receiver
RX-V800 shuts off after 7 seconds turned it on, what should I do?
I'm Electronic Engineer and I have been trying to fix a RX-V800, I replaced two bad transistors Q22A and Q22C(Front right pwr)and drivers. After this action, it didn'n work when pushed its stby/on, now its display keeps light on for 7 seconds approximately then it turns off. Maybe the protection circuitry has been activated. For working properly, does it necessary to connect all the speakrs? How does Protection Circuitry work? By the way, I have RX-V800's electronic diagram. All the best, Rasgador
  • Rasgador Sep 17, 2007
    Just let you know that I fixed this problem, in fact, I have forgotten to fix ground's screw (G2) or (TP00385), the mainly ground on RX-V800's Board. After did do that, to fix ground's screw on Main board, the RX-V800 worked properly.
    Thanks Anyway.
    All the best,
  • Rasgador Sep 18, 2007
    For you too!!!
  • 150 Answers
Can you post that diagram here? Or you can email it to me. I can't make any promises, But Im glad to help, I have done much board work in my time, and this one just sounds interesting. L8R
Posted on Sep 17, 2007
  • Patrick McGee
    Patrick McGee Sep 17, 2007
    Good luck again.
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
Yamaha RX-v800 av receiver will not power up. Was playing and just shut off & will not powere up again. Was in a stereo/tv cabinet with closed glass doors. Cabinet compartment has vent holes in back....
Mine did the same thing two days ago. No reason to suspect overheat as mine is in the open. Could be the power supply? Mine comes on after sitting for a while.
Nov 18, 2009 | Yamaha RX-V800 Receiver
Low TX PWR/ATU won`t tune. No SWR and ALC metwr reading?
You've replaced the pre driver, the drivers and finals. Set bias and still low output. The pre driver is the same transistor used as the tx exciter transistor on other pcb chassis on bottom of radio. Follow the gray coaxial wire from the pre driver on the RF circuit board back to the tx/rx i.f. Circuit board. The gray coax cable plugs right next to the tx exciter transistor on this pcb. Again it's on a different pcb all together and on the bottom of the radio and also. Replace it! And check for open bias or emitter to ground chip resistor next to it. You will get your drive back. Very few rigs have I seen the actual Finals blown in the mosfet or the bipolar version. Just the driver stage with a week pre driver and the SMT "pre" pre driver on the same RF pcb. And the tx exciter on the other pcb.
Apr 24, 2009 | Computers & Internet
No picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Mar 19, 2009 | Yamaha RX-V800 Receiver
Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Jan 06, 2009 | Yamaha RX-V800 Receiver
Has gone into proctective mode
Audio amplifiers IC´s damaged you need to replace him
Oct 16, 2008 | Yamaha RX-V800 Receiver
if you can identify whats blown what ic or pcb board. you can get it replaced through yamaha. or many other various used reciever parts lists online. If you wanted to identify the transistor thats blown find it online and just resolder that one you could do that. But id say try and look into a replacement of the board. if you shorted the poles, then there will be a lot more damage on that channel then the amps final maximizer, or amp as you refer to it. -Thanks Nate
May 17, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V 800
give me more details of trouble... let me give you advise if it can be done. 800 does not have industry standard parts mostly by yamaha only or made to order by yamaha. I have the same unit before, i have the manual too.
i use to work with yamaha service saudi arabia 6 years
Feb 24, 2008 | Yamaha RX-V800 Receiver
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
Feb 04, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Receiver Logo
267 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
