Question about Dryers
Ground wire I am changing out a replacent cord for my Admiral super capacity dryer.The ground wire goes to a green screw. There are two choices,on the left is a green screw with a skinny yellow and green wire. On the right is a green screw with a white wire. Which screw is it? OR do I just put the green
    President:
  • 1,865 Answers
The ground wire needs to be attached to the dryer frame, either screw will work
Posted on Apr 16, 2009
The outlet to plug in my dryer in is a 4 prong but the admiral super capacity dryer is only a 3 prong....i got da replacement 4 prong but when i went to replace the cord the dryer only had 3 wires that are...
2 prongs are for ground and 2 for voltage assuming you live in a mobile home where 4 prongs are required , if you do not know where they go HIRE an electrician
Oct 15, 2017 | Dryers
Need to know how to connect power cord with four wires...
this should be a 30 amp 4 wire plug for a dryer white to center take off the ground strap from the center white post that bolts to the green ground screw u want to isolate the ground green wire goes to green ground screw, black and red goes to outside screws one left one right
Apr 22, 2013 | Dryers
How to hook up a four prong electrical cord, to a three connector dryer?
On the 4 wire cord the white wire goes to the center post on the dryer. The green wire goes outside the terminal cover to the ground screw. The red and black wires go to the right and left terminal post on the dryer. It does not matter which goes right or left.
The green wire could also be attached with the white wire in the center.
Aug 19, 2011 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
I need to change powercord from a g & e electric dryer.it ends into like a square black block,going inside dryer.
It depends on what type of cord you are changing to. I think what you're describing as a sqaure black block is the terminal block.
If your new cord has four wires, should be black, white, red, and green. If this is the case, it goes like this:
Black to the far left screw (L2)
White to the middle screw (N)
Red to the far right (L1)
Green goes to the cabinet, usually behind a green screw.
If this is the case, you're changing from a 3 wire cord to a 4 wire cord, and your 3 wire cord is still connected; then behind the middle screw is probably a strap connected underneath it. When you change to the 4 wire cord, bend and push the strap up out of the way for future use if needed. It acts as the ground for the 3 wire cord.
With the 4 wire cord, the green mounted to the cabinet acts as the ground.
Now......
If i'm wrong with the above, and you're intalling a 3 wire cord; they could all be the same color (the wires). If so, just put....
The far left wire to the far left screw.
The middle wire to the middle screw with the strap attached to it.
the far right wire to the far right screw.
I hope this is helpful, and that I havent completely misunderstood you and wasted your time. I would be glad to help any further if you need it.
Thanks,
Mike
Jul 26, 2011 | Dryers
Need to know about the wires to hook up electric cord there is a red,white,black and green cord but only room for everything but green...what do we do with it
Take any screw out of the metal on the frame of the washer and place the green wire under the screw...the green is a ground...
heatman101
Feb 11, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Have an old maytag dryer and need to replace 3 prong cord with 4 prong. How do we attach color coded wires?
First make dryer is unplugged !!!!!!!!! remove cover near cord entrance to dryer, you will notice 3 terminals. you should also see a green screw close by. there may be a wire or strap connecting center terminal to the green screw or ground. remove wires from terminals and remove strap from center to ground screw. connect new cord in the following order. green wire to green screw or ground, white wire to center terminal, black wire to left terminal, and red wire to right terminal. now you are done put the cover back on. I'm glad you asked this question. this is a very popular question. Your new 4 Prong cord is up to current code. I'm happy to see people updating there appliances to current code and making their homes safer. Thanks
Aug 29, 2009 | Dryers
Need help with changing the dryer cord from a 3 prong to a 4 prong cord.
The 4 prong dryer cord white wire goes to the center terminal connection. The green wire goes to a external ground(any screw) outside the terminal cover. Red and black wires go right and left of the white center wire. Does not matter which is right or left.
Jun 05, 2009 | Crosley Dryers
Dryers Logo
83 people viewed this question
Top Dryers Experts
