Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Can't cancel cycle without it starting
(Brand new dishwasher.) I accidentally pushed 'Normal Wash' on my dishwasher so I tried pressing 'Reset'. When I did that, the dishwasher started it's wash cycle. I opened the door to stop the cycle, but now it beeps every 30 sec, letting me know I stopped it during a cycle operation. *All I want to do is to cancel the wash cycle*. But it won't let me reset while the door is open, and I can't reset it if the door is closed, and it starts washing again.
  • 1 more comment
  • Anonymous Dec 18, 2007
    I have the same problem.  I had a power outage and started the GE Triton dishwasher.  After I started it I discovered that none of the settings were highlighted.  I opened the dishwasher but could not get the reset button to work.  The dishwasher washes for a while and starts beeping.
  • Anonymous Dec 31, 2008
    yep I have the same problem. all I want to do is reset the darn thing!!!
  • Anonymous Mar 15, 2014
    New dishwasher stops quite often during cycle
    Is this normal
    New Friend:
Since none of the suggestions on the internet worked at all to reset my Bosch dishwasher, I took a shotgun an blew the **** thing to smitherines! I feel much better now.
Posted on Jul 28, 2012
    Novelist:
  • 148 Answers
You have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
Posted on Dec 28, 2007
SOURCE:
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Not sure which dishwasher I have it is a stainless steel tub, it is blinking 7 times and when you click cancel it goes back to try the cycle makes a noise and stops.
reset the dishwasher.. turn off breaker for 5 minutes, turn back on, then press: with door open high temp wash energy save wash high temp wash energy save wash close door then press cancel then press normal wash. This should reset it. good luck
Jan 28, 2011 | KitchenAid 24 in. KUDP02FR Built-in...
How do I Cancel a wash cycle? I have no manual
The Reset button is the correct button to cancel the cycle, it takes up to a minute or so the drain. If the buttons are not responding, there could be a problem with the door closed switches.
Jun 08, 2010 | GE GLD5800L Dishwasher
The "cancel" light blinks on and off rapidly. If we push start for the cycle the dishwasher clicks off and on intermitently.
To solve this you will have to reset the console. Do this by closing the door and press these buttons in sequence
-high temp wash -heated dry -high temp wash -heated dry
After doing this sequence all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).You should now be able to run the dishwasher as normal.
Thank you!
May 16, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
428 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
