Question about Water Heaters
AO Smith water heater won't fire. Pilot light is on. Gas valve is White Rodgers 37c73u 238. Is 37c73u 168 a direct replacement? With pilot light on, and turning control knob from max cold to max hot, it will not turn burner on. I have 2 identical water heaters. Other works fine. Terry
  • Anonymous Mar 17, 2014
    I have three electric baseboard heaters controlled with a low voltgage thermostat via a white Rodgers relay. Heat won't turn off with thermostat all the way down and I even disconnected it. Relay is only one year old.
  • Anonymous Mar 27, 2014
    burner will not fire up pilot is on
  • 74 Answers
I bet your thermo couple is bad or your ports are clogged? How old is the unit?
Posted on Apr 16, 2009
Sometimes water is very hot other times luke warm at best.
flush the lime buildup out a 3/4in full port ball valve with hose adapter. Should do for the drain
Sep 19, 2015 | AO Smith A O Smith Water Heater Hot...
Water heater pilot lights no burners
The thermocouple must be defective. Thermocouples convert the heat from the pilot into milli volts to open the gas valve. This is a safety to ensure there is a flame, so the gas doesn't just build up (that can cause an explosion)
Jan 16, 2013 | A.O. Smith BTN-200A Commercial Tank Type...
After years of problem free hot water the pilot light went out and now when trying to re-light the pilot light as per instructions it does not light although the spark is strong and hitting the ther
look at label on side of unit, then add a comment with Brand and type of gas water heater.
AO Smith tank-type, or Rheem tankless so expert can suggest best solution.
Tank-type:
Gas control could be bad.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Water heater is in lockout because combustion chamber overheated and tripped FV system because air intake is clogged.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Oct 10, 2012 | Water Heaters
I have smoth's hot water tank. problem is pilot lite is off. how do u turn it on?
You have tank-type gas water heater with standing pilot light.
Instructions for lighting pilot light are usually on front of water heater.
Since water heaters vary widely, if you want specific information without guessing, then add a comment with model number that appears on label on side of tank, and also describe the gas control valve on front of unit.
This information will let expert located manual and look up specific information plus troubleshoot steps for that model.
Aug 24, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Jul 18, 2011 | Water Heaters
My white rodgers control panel is set on vacation (green light) is on. I have held down the arrow buttons to get it off of vacation mode but it is not working. Obviously i need to switch it off as we have...
Water heater and gas valve are not clear:
Add a comment with description of water heater and gas valve for possible help.
Open following link for White Rodgers intelli-vent gas valve thermostat:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
1) Typical instructions for Kenmore and AO Smith water heater with Intelli-vent say:
Set on-off switch to ON position.
Hold down both arrow buttons for 1 second.
Then press hotter button.
2) Also check that 120Volt electrical outlet has power, and check outlet with cheap circuit analyzer from home center.
3) If Intelli-vent gas valve thermostat is malfunctioning, and won't reset, then contact manufacturer of water heater for replacement gas valve.
Label on side of tank will have Model number, manufacturer, type of gas LP NG, serial number for part ordering.
Add a comment for more help.
Jun 10, 2011 | White Rodgers Water Heaters
Atwood gas waterheater with white rodgers gas valve pilot hard to light and not a big enough flame to touch the thermocouple
I think you need to reposition the thermocouple, or adjust the pilot gas pressure by adjusting the pilot screw make sure it is still the recommended gas pressure of the system... please contact a HVAC tech if this things did not work.
Aug 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Gvr 40 100 will not stay lite
The Cold air screen on the bottom of the water heater is partially plugged. That is if the pilot light can be lit and stay on, but goes out when the heater should be functioning normally. This is not the removable plastic screen but a round white-yellow grid with 1/32" holes. You can try to clean it through the bottom but you may have to remove the gas line from the controller to the burner, pilot gas line, and thermocouple connection to remove that complete assembly to get access to the screen. The AO Smith booklet warns of this but they pretend the plastic screen will keep this second screen clean but it won't. After three years it was two thirds plugged.
Dec 12, 2009 | RTO W4 A.O Smith Gas Hot Water Heater...
AO Smith water heater about 4 years old pilot went out took out piolt assembly cleaned and was able to relight pilot unit stayed working for about 2 weeks and went out again any ideas?
It sounds like your flame detector (usually a thermocouple) has gotten weak and when you cleaned the pilot the stronger flame was able to generate enough power to keep the gas valve working. If you replace the thermocouple your problem should go away. If a new thermocouple will not keep the gas valve operating...the coil in the gas valve has gone bad and you will need to replace the gas valve assembly. (most valves do not have replaceable coils).
Sep 10, 2009 | Reliance Water Heater #9003531 NAT Gas...
Water Heaters Logo
1,066 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
