Question about Garden
It won't stay running
Would not start, cleaned out fuel bowl nothing in it. can dump gas in carb will start for moment
  • Corey McConnell
    Corey McConnell May 11, 2010
    It seems to not be drawing from the tank, sometimes there is a fuel filter in the tank. Is this filter clogged? Check the fuel line from the tank to the carb.
2 Suggested Answers
tse22
  • 103 Answers
SOURCE: It won't stay running
You need to either clean the carb really good (take it apart) or rebuild it or both. Sounds like your needle is gummed up and not letting fuel through.
Posted on May 29, 2009
Troy-bilt 34322 343220110815 mower will not start
Dump out old gas. Fill with fresh gas. Always use Stabile in gas. Clean or replace park plug and air filter. Check oil level. All mowers have a low oil start cutoff. 30w oil. If any grey in oil moisture contaminated, dump out old oil and refill. Check fuel line for cracks or leaking. Check primer bulb for cracks, replace if required. Clean outside of carb with carb cleaner to ensure easy choke operation. Remove carb bowl from carb, ensure float hangs down freely. float down fuel flow, float up fuel flow stops. Check bowl screw for hole thru bolt, if so clean out hole.
Sep 11, 2012 | Troy Garden
Hi, I have a Craftsman Eager-1 5.3 3-in-0ne solid state enigine lawn mower..got it used but in almost new condition. worked great cutting 1 1/2 ft of very wet grass for a few hours (couldn't get to it...
Drain the fuel or when you remove the float bowl bolt (also the main jet), then hold up on the float to keep the needle on the seat so gas won't go everywhere. When you have that brass bowl bolt off, clean it! Use nothing metal on it. Pay close attention to the small hole in the bottom and along the smooth unthreaded part at the other end. Use carb/choke cleaner to blast gum and dirt out of those very small fuel orifices. I recommend installing an inline fuel filter also. A shut off valve is recommended too, that way if the needle in the carb sticks open, the crankcase won't be polluted with gas. Usual symptoms on a clogged lawn mower main jet though, are after pushing primer bulb, engine runs about 3 seconds. Try the brass bolt cleaning and post back if needed.
Jun 14, 2011 | Garden
It won't run and dumps fuel.I've dipped thecarburetor and cleaned it well.the fuel just runs out the lower spring covered house that dumps out onto the ground
The problem is a bit of trash is preventing the float needle from closing fully to stop the flow of gas. Try this; drain the float bowl then close the drain and turn on the gas. Tap the float bowl solidly with the end of a screwdriver handle. The object is to free up the float / shake loose the trash. If doing that a couple of times does not fix the problem, Remove the float bowl and spray the interior of the carb using spray carb cleaner. Pay special attention to the float pin area. With the float bowl off you should be able to gently lift and lower the float. Lifting should shut off the gas and lowering should let the gas flow again. If the float shuts off the gas when raised, put the float bowl back in place and see if the carb still over fills. If so, then the float is defective and you will need a new one. Please rate my answer. Thanks. tombones49_151.gif
May 30, 2011 | Kymco 990 Super Duke Black Motorcycles
Will not stay started Runs for about 1 minute
fuel issue. probably has junk in the carb bowl that gets sucked up when the machine start. You might be able to get away with just taking the bowl off and dumping it out (you will see it there is junk in there. then dump out the gas thats in it and put fresh gas in. Ideally you should clean up your carb which is not that difficult. an air compressor on very low pressure will provide some assistance (10-20 PSI)
Aug 23, 2009 | Garden
Craftsman eager-1 3.75 mower will not stay running
the engine is not getting enough gas. when you hold down the primer you are bypassing this problem. to fix this simply adjust the carb's fuel screw, located on the side of carb, a little at a time until runs smoothly.
Jun 24, 2009 | Craftsman Garden
May 29, 2009 | Honda Pressure Washer PSI 3000
CRF230 - Throttle won't turn. Can see the cable moving at the carb but the carb won't move. Also, have gas coming out of the overflow.
The overflow problem is a carb float being stuck open. Turn off the gas and drain the offending carb(s). Next, turn the gas back on and sharply tap the float bowl with the plastic handle of a screwdriver as the fuel bowl refills. The goal here is to vibrate the float to free it up. If doing this process a couple of times doesn’t free the float I would remove the offending carb(s) and clean with a spray carb cleaner. By the way, Check the float, it could be filled with gas instead of air. Clean the air filter then re-mount carb(s). Next, remove the water trap bowl at the bottom of the petcock, (gas valve). Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Install an in-line fuel filter.
The lack of movement in the carb slide is either a bad cable or the the carb is a CV model. The slide on a CV carb will not move unless the motor is running. Start the motor. Does it speed up normally when you twist the grip? If so, then there is nothing to worry about.
Apr 16, 2009 | 2003 Honda CRF 230 F
My v-star 1100 has not been run in over a year. fuel leaks when trying to start. Whats wrong?
This sounds to me like a carb float being stuck open. Turn off the gas and drain the offending carb(s). Next, turn the gas back on and sharply tap the float bowl with the plastic handle of a screwdriver as the fuel bowl refills. The goal here is to vibrate the float to free it up. If doing this process a couple of times does not free the float I would remove the carb(s) and clean with a spray carb cleaner. Clean the air filter then re-mount carb(s). Next, Remove the water trap bowl at the bottom of the petcock, (gas valve). Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Install an inline fuel filter.
Apr 11, 2009 | 2006 Yamaha V Star 1100 Custom
Carb leaking
You have a carb float stuck open. Turn off the gas and drain the carb. Next, turn the gas back on and sharply tap the float bowl with the plastic handle of a screwdriver as the fuel bowl refills. The goal here is to vibrate the float to free it up. If doing this process a couple of times does not free the float I would remove the carb and clean it with a spray carb cleaner. Be sure main jet is clear. Clean the air filter then re-mount carb.
Next Remove the water trap bowl at the bottom of the petcock, (gas valve). Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Install an inline fuel filter. Turn the gas on, wait a moment for the float bowl to fill with gas then give it a try.
How long since the carb was serviced? Has the bike ran properly since the service?
Please rate this solution. Thanks!
Apr 03, 2009 | 1995 Honda CB 250 Nighthawk
Mass flooding piston cylinder
This sounds to me like a carb float being stuck open. Turn off the gas and drain the carb. Next, turn the gas back on and sharply tap the float bowl with the plastic handle of a screwdriver as the fuel bowl refills. The goal here is to vibrate the float to free it up. If doing this process a couple of times does not free the float I would remove the carb and clean it with a spray carb cleaner. Be sure main jet and float needle are clear. Clean the air filter then re-mount carb. Next Remove the water trap bowl at the bottom of the petcock, (gas valve). Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Mar 28, 2009 | 2003 Suzuki RM 125
Garden Logo
141 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
